My build so far
Discussion in 'SRT Hellcat Builds' started by HellcaTim, Feb 24, 2016.
  1. HellcaTim
    HellcaTim Hellcat Member
    Jun 15, 2015
    47
    10
    Fair Lawn NJ
    I have a 15 6 spd. Not really a build but..
    I have gotten into the 11s but im spinning the whole way. Average mph is 123 to 124 on the summer street tires.
    So for now I'm going to run a set of Welds 17x9 with Racemaster DRs, carbon fiber driveshaft and a short throw shifter.
    should be fun times this season. Hopefully my traction issues will be gone for the most part.
  2. Rocky_Rhode
    Rocky_Rhode Senior Hellcat Member
    Oct 20, 2015
    87
    51
    Spinning is one thing; beware of any wheel hop with the M6 as that can turn components into shattered metal fragments. Likely scenario, however, as with most so far the driveshaft will go saving more expensive components as it appears to be a universal weak link.
  3. HellcaTim
    Jun 15, 2015
    47
    10
    Fair Lawn NJ
    I agree, thats why I want with 17x9s. I figure the sidewall will eat up most of the shock and only 9 in wide the tire is a 275 so width is around the stock width. plus its saving 30lbs over all over the stock wheels and tires. There is a method to my madness
  4. FireLane
    Jul 23, 2015
    398
    117
    Palm Beach County, FL
    You will need to replace the clutch with an aftermarket one if you're going to put drag radials on
  5. Sepipr21
    Sepipr21 Silver Member
    Oct 17, 2015
    405
    49
    I was going to ask about the clutch. Let us know if it's holds up. And good luck.
  6. Sepipr21
    Oct 17, 2015
    405
    49
    Does the shifter makes a difference? What kind of shifter do you have?
  7. HellcaTim
    Jun 15, 2015
    47
    10
    Fair Lawn NJ
    Book difference according top Hurst is 33%. Now is that 33% less throw, or 33% quicker shift? IDK, maybe i just am readfing it wrong.
    As of right now Im not doing a burnout or launching on the summer street tires, best 60' so far is a 2.0 with a trap speed of 123.55mph and i forget the ET. It was high 11s if i remember correctly.
    So with that i figure do the same except clearly do a burnout to put heat in the DRs. I should get much better times without a launch.
  8. DAVIDELOWE
    DAVIDELOWE Hellcat Member
    Jan 18, 2016
    51
    13
    TULSA, OKLAHOMA
    How many launches do you think it would take. I figured something else would let go before the clutch on a hard launch
