Need a fuel system wiring diagram P0125A
Discussion in 'SRT Hellcat Electronics' started by HCone, Jul 7, 2015.
  1. HCone
    HCone Gold Member
    Dec 4, 2014
    1,053
    308
    Can anyone supply me a fuel system wiring diagram ?
    I have had a P0125A code for 2 months now, dealer seems perplexed.
    I have personally crawled under the car and checked whatever connections and wiring I could find, even changed the fuel pump relay ( on my nickel ), and still have an engine light come on and a high pitch whistle from the fuel pump trying to release the excessive fuel pressure after about 20 minutes of driving.
    I need to start tracing wires, so a diagram would greatly help.
    Any input would be appreciated
  2. Paladin06
    Sep 3, 2014
    4,642
    1,787
    San Tan Valley, AZ
  3. Fast cat
    Sep 23, 2014
    2,255
    713
    498
    Indiana
    Or fnkychkn , might be helpful
  4. fnkychkn
    Jan 24, 2015
    1,451
    558
    423
    plastic take-out container
    i would be perplexed also, as P0125A is not a valid code.
    • Funny Funny x 1
  5. HCone
    HCone Gold Member
    Dec 4, 2014
    1,053
    308
    sorry, meant to say P025A, thanks again for the reply
    Car showed a P026A yesterday as well...arrrgh !
  6. B5 Blue
    1,743
    To give them/you a different way of looking at it remove a pin starting with easiest. So pin 72C at power distribution block remove it with engine running and see what engine does and what code sets. If not same code then that ain't the wire and so on.
  7. HCone
    HCone Gold Member
    Dec 4, 2014
    1,053
    308
    Thanks B5, I'll give it a shot, I have an appt tomorrow afternoon at dealer again
  8. B5 Blue
    1,743
    Let me add that let's say pin 72C does emulate the code they're not done unless they see an obvious issue with the pin or component it plugs into. The next easiest pin gets removed after DTC cleared to see what it sets. It's possible to have more than one wire set the code is bottom line.
  9. moparbrad
    moparbrad Hellcat Member
    Jul 8, 2015
    59
    12
    Florida
    It looks like they are either going to find a short or bad pcm, only a few possible causes of that code
  10. Alan
    Alan Active Hellcat Member
    Sep 8, 2014
    100
    33
    28
    This code happens because the wire from PCM pin 83 to FPCM pin B (PWM Control) is open circuit or has an intermittent connection somewhere in between.
    • Useful Useful x 3
  11. HCone
    HCone Gold Member
    Dec 4, 2014
    1,053
    308
    Thanks Alan, I will be sure to post the results, when we find the issue
  12. HCone
    HCone Gold Member
    Dec 4, 2014
    1,053
    308
    FC, do you have a diagram available showing exactly where Pin 83 and B are located?
  13. Dragon
    Dragon Gold Member
    Oct 16, 2014
    658
    229
    AZ
    time to go to a different dealer
  14. HCone
    HCone Gold Member
    Dec 4, 2014
    1,053
    308
    FCA tech is directing the dealer thru the steps,but thanks for your most valuable input
    I have the car here and am trying to maybe get lucky and sort it out myself before it goes back to the dealer tomorrow. I have a trip planned this weekend and am paranoid to take it as it is.
  15. B5 Blue
    1,743
    If Alan is correct which I don't doubt that wire has a connection #2 in between and that's where I'd look may not be seated right but I don't know where it is
2016 hell cat challenger fuel system
2016 hellcat fuel pump wire diagram
dodge hellcat ecu pinout
fpcm for dodge charger 2014 location
fuel pump pinout 2015 hellcat
location of fuel module pump control for dodge hellcat
pwm fuel pump electrical diagram
