Need help urgent
Discussion in 'SRT Hellcat Appearance' started by hmd_82, Dec 5, 2015.
  1. hmd_82
    hmd_82 Rookie
    Aug 7, 2015
    25
    17
    I installed KW Height Adjustable Spring System on my HC and after a while the suspension mode don't change at all and stay on sport mode also no the dashboard it says service dampening active system . Any ideas how i can fix that ???
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,781
    2,048
    There is a lady on Facebook named Julie Cain, she had this installed on her hellcat, maybe she will have an answer, until someone chimes in
  3. Shake&Bake
    Shake&Bake Back to (1) Club?
    Mar 9, 2015
    1,260
    780
    733
    The United State of Texas
    That's weird, I have the same set up on mine, and never had any trouble. Try disconnecting the battery and see what happens.
  4. hmd_82
    hmd_82 Rookie
    Aug 7, 2015
    25
    17
    Will see hopefully someone show up
  5. hmd_82
    hmd_82 Rookie
    Aug 7, 2015
    25
    17
    I already disconnect the battery it goes and after a minute it show up again. I also disconnect the dampening system unit which is located on the trunk driver side and it come back again
    Check that out
    Sensors Suspension and Steering
  6. graycat
    graycat Automobile Aficionado Extraordinaire
    Oct 1, 2015
    1,355
    526
    Knoxville, TN
    hmd_82....Any chance that you are in UAE or the Kingdom? If so I am afraid that finding a properly trained tech to work on your car and help
    you with it is close to nil.
    You are the fourth person that I have saw online with this system or with lowering springs that have had the same issue with the computer.
    There must be a way to "trick" the computer into not acknowledging there is something different from factory on the car. Have you tried contacting
    a Dodge dealer (another reason I asked about your location)?
    It may be possible to relocate some sensors to accomplish this "trick"
    Best of luck to you!!!
  7. hmd_82
    hmd_82 Rookie
    Aug 7, 2015
    25
    17
    Green cat , thank for the reply. I'm located in Qatar and I've already contact the deale regarding this issue and they have no idea. Moreover, the dealer here is the worst ever in the planet and don't know how to do maintenance other than oil changing , also the never have stock, most of the parts the order from Dubai .
    Hope someone come up with solution
  8. graycat
    Oct 1, 2015
    1,355
    526
    Knoxville, TN
    I know it must be very frustrating to have a nice new car and not be able to find support for it when you need help. Have you tried to contact
    KW regarding this problem? Being that they produce the parts I would expect that they should have some experience with the parts and with
    the Dodge products in general if not the Hellcat specifically.
  9. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    Check diagnostics on dash if you have a code list it here if not report back.
  10. graycat
    Oct 1, 2015
    1,355
    526
    Knoxville, TN
    TallCool1...Good thought, there may be something unrelated to the KW system or someone may have goofed up something else during the
    install that will give a code. I'm embarrassed that I didn't think of that.
  11. hmd_82
    hmd_82 Rookie
    Aug 7, 2015
    25
    17
    There isn't any code on the dashboard , it was ok for a while then something go wrong specially after install weld racing wheels with Shortened Rear Sway Bar End Links
  12. TallCool1
    2,439
    831
    Pacific NW
    Thanks I'll send you a pm tomorrow.
  13. hmd_82
    hmd_82 Rookie
    Aug 7, 2015
    25
    17
    Thanks bro
  14. graycat
    Oct 1, 2015
    1,355
    526
    Knoxville, TN
    If you replaced the wheels the speed sensors (for the speedometer) or even the tire pressure monitoring system may have an issue that the
    computer sees and has caused the car to lock you out of some functions.
    I could be way off base and just plain wrong here, just trying to help you ask the right questions of someone that does know.
    Any ideas TallCool1?
  15. TallCool1
    2,439
    831
    Pacific NW
    Go here download the attachmen's examine all suspension wiring (around shocks) in your car you might find the cause yourself. I can't get to diagnosis instructions based on the cluster message until tomorrow.
    suspension: how does it work? | SRT Hellcat Forum
