NEED MASSIVE HELP ASAP!!!! THANK YOU!!
Discussion in 'SRT Hellcat Builds' started by gilgamesh, Apr 2, 2016.
  1. gilgamesh
    gilgamesh Silver Member
    Sep 20, 2014
    356
    120
    OK, I am screwed....
    My buddy and I are working on doing the Metco 2.85 upper and we are having MASSIVE issues.
    We have been turning on the pully for over 1 hr and it keeps spinning the shaft. We are immobilizing the pins but the bolt keeps turning and backing out. We re-tighten and go again, and it keeps doing it.
    Has anyone else had this issue? Does anyone know a solution? We are making NO progress. If anyone would like to call me and walk me through this, I would owe you my first born.
    We are turning COUNTER-clockwise.
  2. jvm728
    jvm728 SRT Hellcat Supporter Gold Supporting Member
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    This is all correct. I originally took out the bolt in between the pins on the backside, then realized I didn't need to.
    Torque the crap out of that (above 100 ft lbs for sure). Then fix the pins, use the metco key for the front hex at the center of the supercharger pulley, and turn it counter clockwise, like you're doing. I ended up doing this job solo, but in my shop I have all sorts of weird conveniences
  3. jvm728
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    I think when I put the new pulley on I torqued it to 120ft lbs. would have to check my build thread
  4. gilgamesh
    Sep 20, 2014
    356
    120
    OK...I wasn't sure how far down to torque that thing....
  5. gilgamesh
    Sep 20, 2014
    356
    120
    Thank you for the help, I was worried I had broken something in the shaft.
  6. jvm728
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    Did you get it taken care of and done? The only thing you want to be sure of is to make sure you're locking those pins as far and close to the housing as possible.
  7. gilgamesh
    Sep 20, 2014
    356
    120
    Nooooooope, it went from bad to worse. We torqued the bolt to 65lb and it snapped the head off. Now I have to find a place to get the bolt drilled out.... :(
  8. Wack_Cat
    Wack_Cat Silver Member
    Feb 5, 2016
    195
    32
    Northern Colorado
    No big thing don't sweat it. Head to Sears and get a left handed drill set. The worst case is call metco and they can send you a new one. Don't sweat it crap happens
  9. jvm728
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    Agree with wack. If the head popped off you really just need to drill so you have something to grab onto. Should come right out.
    I'd take a deep breath. Maybe take a day off, and come back with clear mind.
  10. jvm728
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    Maybe someone can find the actual torque specs for you
  11. gto19
    gto19 Silver Member
    Aug 18, 2015
    521
    This so sucks :(
  12. gto19
    gto19 Silver Member
    Aug 18, 2015
    521
    The center Bolt were talking about
  13. Wack_Cat
    Feb 5, 2016
    195
    32
    Northern Colorado
    Yes Sir.
  14. zippy
    zippy Silver Member
    Feb 2, 2015
    358
    129
    Ontario
    Sorry to here your troubles
    That bolt does not need to be removed at all for pulley install, just get it out and replace it then use the metco pulley tool on the opposite side while holding the pins stationary. No need to touch that bolt.
    Just hope you didn't strip the threads in the aluminum. Idoubt it since you snapped the head off. Its probably an aluminum bolt as well.
    Best of luck
  15. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
    I thought you where supposed to use the pins to hold it from turning.
you are the man
you da man
