Need to tap into signal for high end audio gear.
Discussion in 'SRT Hellcat Electronics' started by Doc Fluty, Aug 4, 2015.
  1. Doc Fluty
    Doc Fluty Gold Member
    Feb 26, 2015
    155
    190
    493
    Hello
    I am about to start tearing into my HK system for my 2015 challenger.
    right now i have a set of Focal K2 Power 165 KRX3 and two Focal Solid 2 amplifiers. I plan on adding a Helix DSP, two 12" subs and more gear relatively soon.
    My question is, has anyone actually got into the HK system yet and found a way to grab the signal before it gets to the amp (where ever that is). I would like to be able to get that signal and take it to my DSP before the factory amp adds its own noise to the process.
    And if i cant grab it before it gets to the amp for whatever reason, where is the amp so i can grab it after it?
    thanks for any help you can give.
  2. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    sheesh,no input, other than good luck
    Let us know how you make out
  3. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    Now you got me thinking
  4. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    The amp is under the sterring column area. I have added some alpine subs to my car. The amp is a multi channel amp with built in crossovers.
    I only grabbed the factory sub as it was crossed over already. I tried the rear deck 6x9's but there is no lows going through them
    I am also interested in grabbing the signal before the amp but I don't believe it vol controlled as the volume is through the can bus.
    You will have to take them after the amp but each speaker only has selected frequencies. I have not been able to get what those are for each speaker yet
    Good luck
  5. Fast cat
    Sep 23, 2014
    2,255
    716
    498
    Indiana
  6. Doc Fluty
    Feb 26, 2015
    155
    190
    493
    I spent a lot of time trying to listen to frequencies to see where speakers transitioned. The sound in the doors kicks in at 35hz but doesnt actually produce a quality sound until almost 55-62hz... which tells me that a high pass crossover could really help with some of those pesky door rattles.
    If you go on youtube and play "hearing test 20hz to 20khz" you will learn a lot about your system... the dramatic shifts from left to right, the dead spots and the absolute nothing beyond 13700 khz.
    I believe the frequencies changes from the door to the dash somewhere in the 170-209 range... but its hard to tell because if my door is open i get a damn chime for forever... i really need to disconnect the dash speaker to get a real test result though.
    the sub is wacky.. could use a low pass crossover as well... despite these things not really having magnets, they start at about 30 hz and have a dramatic increase in volume at 59-72 hz..
    like i stated above, I already have a Focal 3 piece system for the fronts and now four separate focal amps for power (2 for the front components and 2 for subs)... im still deciding on actual subwoofers and sub box design though. Most likely something in the floor facing up similar to the factory unit so i can keep trunk space.
    Also deciding between a Helix dsp pro, Fosgate 3Sixty.3, Alpine PXA-H800, Audison Bit One and other DSPs...
    once i get the subs and design planned out i will begin the instal.. going to use top installation techniques, custom a-pillars, amp racks, premium fabrics, ect... wish me luck lol
  7. Bigdodge
    Bigdodge Rookie
    Jun 13, 2015
    21
    2
    Kokomo, In
    From my research the jbl ms8 is the way to go.
  8. Bigdodge
    Bigdodge Rookie
    Jun 13, 2015
    21
    2
    Kokomo, In
  9. thedynoguy
    thedynoguy Gold Member
    Jun 22, 2015
    171
    135
    493
    Webster, NY
    I'm headed in the same direction. I did an upgrade in my 2010 F350 crew cab with an Audio Control DQL-8, Focal separates, JL 900/5 amp and JL sub box. The integration with the factory Sync worked out great, and the sound quality in the cab is up a frillion percent. Keep us posted on your progress, and pictures if you have the time...
  10. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    Talk to Crutchfield Tech Support they're familiar with the head end. Probably could help they may have a harness and would be able to provide you specs from there that would answer your questions.
  11. thedynoguy
    Jun 22, 2015
    171
    135
    493
    Webster, NY
    Cruthchfield = maybe. When I did my truck, they insisted there wasn't an external main amp in the system, just the sub amp. They were totally wrong. There is an external amp above the E brake pedal in the truck that they told me didn't exist. Just beware of what they are telling you, as it isn't always fact...
  12. Doc Fluty
    Feb 26, 2015
    155
    190
    493
    I would probably need one of THESE.
    But they dont make them for the 15s yet.. i sent them an email but they have yet to reply.
  13. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    I emailed pac and you are correct there is nothing for the 15's yet. I have used these in the past and you can grab the right and left right full range signals before the amp
    I guess I will wait
    my subs do hit hard with the factory sub crossed signal but I have the gains way down because the car can't keep up. I have 2 kappa four infinity 1200 rms amps waiting. Just need a full range signal for the car. Good winter project.....
  14. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    Doc Fluty well, I had ended up having a separate Pioneer Championship series AMP 1OHM installed for my dual POLK Audio 12" Subwoofers Single air ported. Man they hit real real hard and deep make your bones shake and muscles tense up.
    The factory AMP blows for subwoofer signal I promise you that.
    [​IMG]
  15. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    You can't see in my pic but there is a 2000 rms alpine amp driving my subs. Just feeding the factory sub signal into the amp
    You are right the factory amp sub is not good at all
2015 charger srt8 full range radio signal
2015 dodge challenger srt 392 hk subs
2015 dodge challenger subwoofer
best place to get a signal for a sub amp in a challenger with the alpine 9 speaker system
buy audison 3 way setup
focal 3 way speakers
how to tap into factory wiring to get signal
midrange and midbass differents
