New hellcat throwing codes
Discussion in 'SRT Hellcat General Discussions' started by Redsrt1, Nov 3, 2015.
  1. Redsrt1
    Redsrt1 Rookie
    Nov 3, 2015
    4
    1
    Need some help with my car guys and girls. I have a 2015 hellcat with 700 miles on her. Took the car into the body shop because I have an air leak coming from he rear passenger side quarter panel window . Well the car was in valet mode when they took it for a test drive and when they brought it back it was throwing a p007c and p007d code along with the service air bag light. The service dept replaced the sensors that were faulty according to the obd system. However when I got the car back the mil light went back on and started throwing the same codes again. Needless to say the whole rear quarter panel that encapsulates the glass needs to be replaced and they can't figure out at the moment why the car is throwing codes. Any help would be appreciated guys also car is stock except for a muffler delete.
  2. rayzazoo
    Nov 8, 2014
    3,872
    1,580
    818
    Is this being done as warranty work?
  3. Redsrt1
    Redsrt1 Rookie
    Nov 3, 2015
    4
    1
    Yes it is. But given that they replaced the faulty sensors based off the scan from the obd, now they are at a stand still because they don't know what else it could be.
  4. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,012
    487
    403
    Westchester
    They attempted to fix the glass by removing interior bits, They must have broken or removed and failed to properly reinstall the side/curtain airbags. Typical.
  5. FarAwayFromHere
    FarAwayFromHere Gold Member
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Find Another Dealer In My Oppinion,preferably somewhere tech's have more experienced and most importantly,a tech which has good troubleshooting skills!
    A scan only tells you limited info,you have to be able to get to the root cause,that's the trick...Good Luck!
  6. White Trash
    White Trash BMF Hellcat Car Club HCC Charter Member HCC National Vice Pres.
    Oct 23, 2014
    1,103
    420
    258
    (Undisclosed Classified)
    Find another dealer might be needed if they cant handle the issue.
    I would also call the SRT Hotline get them involved asap
  7. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    Why would they drive the car,, if there is a leak, water test it...that is what they did when I worked at the dealer
  8. Redsrt1
    Redsrt1 Rookie
    Nov 3, 2015
    4
    1
    I guess the tech wanted to hear what I was hearing. Sounds like a window is partially lowered. I'll update this thread when I get some answers as well as my rear quarter panel glass installed. Thanks for the advice.
  9. hellcat1
    Sep 27, 2014
    10,672
    2,033
    Good luck with the car, I'm sure they will take care of your car
  10. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    Good luck!
    I had several codes but there were different and all problems solved on initial visit
  11. Redsrt1
    Redsrt1 Rookie
    Nov 3, 2015
    4
    1
    Update on the car. I was gonna take the car in tomorrow morning so they could replace the rear quarter panel window and at the same time diagnose the engine codes. Well I decided to drive the car to work today. While traveling down the expressway around 85 mph I accidentally knocked the auto stick into neutral for a brief moment. I took my foot off the gas after I noticed what had happened and placed it back in drive. Well to my surprise I lost all engine power and speed just started to decrease. I pulled onto the shoulder and put the car in park and turned it off. I attempted to restart the car and got nothing but engine crank. I tried starting the car a few times but it was a no go, I Checked for codes and p2302 is what came up . Cars at the shop now, hopefully this gets resolved.
  12. hellcat1
    Sep 27, 2014
    10,672
    2,033
    Sorry to hear your still having issues,, hope they can resolve the issue soon, and get you back driving...I can't help but wonder what's going on with your crank pulley...maybe the different torque on the engine did something
  13. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,909
    1,330
    498
    Virginia
    Ouch!
    Keep us posted on what they find.
  14. Dave Cooper
    Dave Cooper Hellcat Member
    Nov 11, 2014
    71
    15
    NJ
    I would email dodge directly , they will respond with answers and even a tech might respond (good luck )
  15. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,378
    436
    Any updates on this one?
