New Product! Hellcat Performance Aluminum Flywheels
Discussion in 'Modern Muscle Xtreme' started by Modern Muscle, Nov 10, 2015.
  1. Modern Muscle
    Modern Muscle Rookie Hellcat Supporting Vendor
    Oct 22, 2015
    25
    15
    Designed by Ram Clutches specifically for Modern Muscle Xtreme, this high performance aluminum flywheel for the 2015 & 2016 Dodge Challenger Hellcat with the manual transmission is a must-have driveline upgrade.
    The choice for most all-out competition vehicles, RAM billet aluminum flywheels are CNC machined from certified materials and exceed SFI standards. A key feature of a RAM aluminum flywheel is the ΒΌ inch steel friction insert*. A well-tuned competition clutch system has a predetermined amount of slippage at launch and on the gear changes. The flywheel insert must have enough mass to absorb the heat generated by slippage without distortion; ensuring maximum clutch life and consistent performance. Thinner inserts can warp and lift causing uneven engagement across the clutch disc. The thicker insert remains flatter and dissipates the heat better. Each flywheel is precision ground after the steel insert is installed to ensure the friction surface is parallel with the crankshaft flange for minimum runout and to provide the optimum mating surface for your choice of clutch disc.
    This product also allows customers with RT & SRT manual applications to upgrade to the Hellcat clutch!
    http://www.modernmusclextreme.com/p-77-hellcat-performance-aluminum-flywheel.aspx
    [​IMG]
  2. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    dave
    Anyone using one and running on the track and does this come with the other parts to handle the HP? would be nice to have another option other than the Big Boyzz Garage set up.
    TC
  3. Modern Muscle
    Oct 22, 2015
    25
    15
    Dave not here LOL
    we just got these in installing soon. Hellcat trans should handle the higher HP but high HP clutches are available
  4. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    Chris, ask Dave if these are for stock hellcats or 900+ HP hellcats,LOL
    TC
  5. Modern Muscle
    Oct 22, 2015
    25
    15
    They will work on either but these are made for the Daily Drivers / Track guys
  6. Top Cat
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    Thanks for clarifying Chris
    TC
  7. hellcat562
    hellcat562 Silver Member
    Jun 4, 2015
    384
    124
    How much for a clutch and flywheel?
  8. Modern Muscle
    Oct 22, 2015
    25
    15
    Are you looking for OEM clutch or aftermarket?
new products hellcat forum
ram clutch for hellcat
ram hellcat clutch
