Nitto 555 G2 put on today (275front, 295Rear)
Discussion in 'SRT Hellcat Wheels and Tires' started by accely, Apr 30, 2016.
  1. accely
    accely Silver Member
    Jan 21, 2016
    196
    Davenport, IA
    Love this tire already and it's a down pour! I switched from stock all season pzero. The 555 G2 is wayy better grip and it looks amazing.
    275/40/20 front
    295/40/20 rear
    I can confirm the driver side rubs on the inner thin plastic guard. Does NOT rub on the passenger side. See pictures and you'll notice there is more room on passenger side, not sure why. I instantly heard the light rubbing of it when I picked it up and it does it not only when turning. Good news is this piece of plastic guard and is very thin and I plan to trim a few inches off once it dries up outside and I'm able to get under it. Should only take a few minutes and it will be good.
    At first I thought it was going to be rubbing on something more substantial but after feeling the plastic guard it's very thin as I said. You're even able to push it away from the tire, which would prevent the rub, but you would need something to keep it pulled back. So trimming it a few inches should be easy enough.
    Will update again once I get to drive it in dry weather but like i said even in this down pour I noticed the better traction instantly. Love them so far and you can't beat the price... roughly 185$ front, 200$ rear. 2016-04-30 12.59.07.jpg 2016-04-30 12.59.37.jpg 2016-04-30 13.01.40.jpg
  2. wewsrt8
    wewsrt8 Silver Member
    Nov 9, 2014
    194
    50
    Centerville, OH
    Nice.....I have the 275 on the front as well, but have 555r on the rear with no rubbing and they are wider than the 295. Must be the overall diameter of the tire.
  3. FINALLYSATISFIED
    FINALLYSATISFIED Silver Member
    May 23, 2015
    577
    136
    San Diego, CA
    555 G2's? Looks like I'll look into this for my replacement.
  4. DGatzby
    Jan 16, 2015
    3,729
    1,992
    748
    Twin Cities, MN
    You do not have to slit the back. Going way back look at this thread on how to easily move the rubber boot over. More problems if you rub the front of the rears.
    Bigger Wheels
  5. goingsolo2
    Oct 29, 2014
    1,569
    645
    Long Island, NY
    How is the handling from the front tires? I may use these once my P Zero Nero fronts are wasted.
  6. accely
    Jan 21, 2016
    196
    Davenport, IA
    I noticed better handling and road feel right away. Grip is definitely better
  7. accely
    Jan 21, 2016
    196
    Davenport, IA
    Update-
    Driven only about 50 miles since I've put on the tires. Avg 5-10 miles a day.
    Had my exhaust replaced due to the squeaky valves (fixed it)
    Also had them put on my rear mudflaps.
    All this and 2 smokey burnouts later and I care barely hear the rubbing noise anymore. Infact with the noise of exhaust it's almost completely gone. I ran my finger back there behind the rear driver tire and it almost seems like there is a tad more clearance (not sure if it's in my head or not). I'm not sure if it was obtained when the mudflaps were put on or not. But at any rate I dont feel the need to do anything to remediate that rubbing anymore. I have to listen extremely hard to hear what I 'think' is the rubbing so forget it!
    btw these tires must be REALLY soft, I did a burnout for roughly 5 seconds and there was a pile of rubber haha, I'm glad their cheap!
    Pic of the front after cleaning...
    • Like Like x 3
  8. Danny123
    Danny123 SRT Hellcat Moderator Staff Member
    Oct 4, 2015
    699
    423
    image.jpeg This is what I did to stop the rubbing on my PS2 305/35/20
  9. bigsursteelhead
    bigsursteelhead SRT Hellcat Supporter Gold Supporting Member
    Sep 21, 2015
    111
    198
    NorCal
    A before and after shot would be good. thanks for posting!
  10. Danny123
    Oct 4, 2015
    699
    423
    Before thought there was enough room with the 305's I was wrong, at the GA Wannagofast after first burn out and run heard this noise and sure enough the drivers inner liner was hitting.
  11. Chippy
    Chippy Silver Member
    Nov 27, 2014
    722
    Alberta
    Just remove the push pin at bottom push liner back a little bit and drill another hole put pin back will give you ample clearance, im running 315 with no rubbing. good luck
  12. PhantomWorks
    PhantomWorks Silver Member
    Feb 10, 2015
    553
    187
    Florida
    Your Rims are very shiny? Did you have them painted or are they wet?
  13. Cglhawk260
    Cglhawk260 Silver Member
    Jul 20, 2015
    357
    135
    CT
    Thanks for sharing ACCELY. If you should hear any rubbing again please give us an update.
  14. accely
    Jan 21, 2016
    196
    Davenport, IA
    I think they were still drying from having applied Eagle1 Keep Clean, helps prevent brake dust build up
  15. accely
    Jan 21, 2016
    196
    Davenport, IA
    Been a few weeks now and still no rubbing since the first 2-3 days.
    I will definitely keep the idea in mind of moving the push pin up if I go larger tire next time. I'm already itching to go bigger, a good reason to light these current ones up! haha
hellcat nitto 555 g2
luckyboot555
nitto 555 hellcat
