Noticeable Vibration
Discussion in 'SRT Hellcat Performance' started by Drig, Mar 22, 2015.
  1. Drig
    Drig Hellcat Member
    Feb 28, 2015
    67
    17
    Florida
    Ok so here's my dilemma after a couple 100 miles. I put nitto 555r 305's on the back, waited until break-in period and took my car up to 120mph. But I'm getting vibration starting at 117 mph and up consistent! Had the balance check and redone and still same issue. also checked the front. I guess I'm going to have to put the Pirellis back on and see if its still there, and go from there. What a pain!
  2. Tammie
    Sep 11, 2014
    13,479
    4,537
    1,223
    Washington
    Interesting. Others have Nittos and I haven't heard any problems similar to this. Let us know if you still have the issue with the Pirellis. Thanks
  3. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,381
    768
    Slinger Wisconsin
    We're they just at blanced it road forced
  4. Dubya
    Dubya Silver Member
    Jan 3, 2015
    717
    202
    I wouldn't change a thing, I'd take it straight back to the dealer like it sits and have them work it out under warranty. All you did was change tires and you're beyond your break in period..no worries.
  5. Mike Canadian
    Mike Canadian Silver Member
    Jan 21, 2015
    278
    66
    Tires could be fine if your tire guy/balancer is calibrated. Might be a slight separation also occurring at high speed if the belts are pulling apart. I agree with putting the factory tires back on and back to the dealer for there diagnostic.
  6. Drig
    Drig Hellcat Member
    Feb 28, 2015
    67
    17
    Florida
    Do you mean like high speed balanced... No
    I don't think its the tires could it be the driveshaft its a 6 speed
  7. Drig
    Drig Hellcat Member
    Feb 28, 2015
    67
    17
    Florida
    His balancers were calibrated 6 months ago and put them on two different ones to check both came up equal
  8. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,381
    768
    Slinger Wisconsin
    Road force is not high speed. I don't think its the shaft
  9. Drig
    Drig Hellcat Member
    Feb 28, 2015
    67
    17
    Florida
    Ok just read up on road force balancer that makes senses!
  10. Drig
    Drig Hellcat Member
    Feb 28, 2015
    67
    17
    Florida
    DrBuick what would make you think it's not the driveshaft?
  11. 1FSTCAT
    1FSTCAT The Punisher
    Dec 28, 2014
    1,129
    407
    358
    Virginia
    and if it turns out to be the tires, get ready for a couple of hours of diagnostics fees. Switch back to your stock tires and roat test it, it the vibration remains...take it in, if not, problem solved.
    • Useful Useful x 2
  12. Mike Canadian
    Jan 21, 2015
    278
    66
    I worked at Goodyear years ago and we would do on the car balancing for problem scenarios...back then it could be drums etc. These days I find even if the tires are sitting too long they will flat spot like the old belted tires. Put it back to OE and check it again at high speed and if you get caught just tell em that Mike said it was okay!
  13. B5 Blue
    1,743
    If it does it at the SAME rpm it's not tires it's some reciprocating part so whatever the rpm you have this at 117mph do the same rpm in other gears
  14. Dubya
    Dubya Silver Member
    Jan 3, 2015
    717
    202
    I put 35x12.5's on my dually and had an issue with a popping in the front end shortly afterward. It took 3 or 4 trips to the dealer before they put a set of chassis ears on it and finally figured out where it was coming from. My tires likely caused the issue but my intermediate shaft was covered under warranty. Every case is different but that was my experience.
  15. SRT_HC_707
    Jan 1, 2015
    4,924
    1,422
    70.196059, -148.559760
    Your tires aren't balanced at every speed. They are balanced for that range around 60MPH. I'm not suprised it's vibrating at 117. Has a lot to do with the tire construction etc.
    I used to not even balance my Nitto DR's as I couldn't keep the weights on the metal rims.
    • Useful Useful x 2
Similar Threads
  1. DNTBTHR
    36
    2,304
Loading...
challenger hellcat vibration
charger srt wheel balance
do unbalanced tires get worse at increased speeds
hellcat challenger axle shaft vibration
hellcat drive shaft vibration
hellcat vibration
srt vibration normal
unbalanced tire vibration 70-75
