NOWEEDS - Can't get anyone to install it? Do it your damn self!
Discussion in 'SRT Hellcat Builds' started by WindowShaker, Mar 20, 2016.
  1. WindowShaker
    WindowShaker Gold Member
    Oct 1, 2014
    760
    428
    VA
    As some of you may know by a couple of my posts on here, I've been looking for an exhaust shop to install my NOWEEDS exhaust diverter system to no avail. Either they were booked (even though they originally told me they don't do appointments :mad:) or they would only do the underneath part, no wiring. So today, I decided to tackle it myself. Although there were a few minor struggles during the install, it was SO worth it. You think the Hellcat sounds good stock? You ain't heard NOTHING yet!
    Spent $15 on a set of plastic trim removal tools. They are worth 10 times that, easily. If you don't have a set, get one.
    Picked up power off the back of the cigarette lighter.
    Used a 3/4" bit to drill out for the rocker switch. Still had to ream it slightly and then cut a tiny notch for the nub on the switch so it would lock into place. I chose this switch type instead of the under-the-seat option for ease of use. It's tough reaching under the seat while driving.
    Switch wired and the shifter is ready to go back in.
    The instructions reference the "bend mark" on the pipes as to where to cut it. I had a pronounced one on the drivers side but absolutely none on the passenger side. I simply measured and lined it up with the drivers side.
    Factory pipes out and heat shield installed. The heat shield was a little tough to line up on the rear side. Had to force it to the right pretty hard to get the rivet in. I'll have to check it occasionally to make sure it's holding in place.
    In and ready to wire. A couple notes here: I had one hell of a time getting the rear connection in on the passenger side. Even after using a screwdriver to spread the factory pipe at the slots, it wouldn't go in. Finally did a little research and WD-40 was recommended. Sprayed just a touch on it, got it started, and then used a block of wood and a hammer and got it in. One thing bothered me, if I had driven the rear connection all the way in, it would have had a pretty good gap at the front connection, on both sides. I ended up with about a 1/2" or so gap on the front and about 1-1/2" of insertion on the rear prior to installing the clamps. It's not leaking, but I thought it would have been a closer fit. I'll have to monitor it and maybe think about welding it at some point.
    Done and done. You lose about an inch and a half of clearance so I'll have to be careful going over speed bumps.
    It sounds SO good! All in all, I would say the install isn't bad. The only things I didn't like were the gap in the pipes but mainly, you're left to your own devices to try to find a good routing for the wires from the passenger side. The wire that's connected to the passenger side actuator reaches about halfway across the car after running it under the heat shield. I ended up taking the drivers side wires as well as the power wires into the middle of the car to meet the passenger side and plugging everything in there. Then you have to find a place to tie-wrap the connections in place. I tied mine to the back side of the transmission cross member. Again, something else I'll have to monitor to make sure they're holding up ok.
    I'm glad I finally got mine installed! It was worth the struggle. Did this by myself with the rear wheels on ramps and the front end on jack stands. It was raining but there was no way I couldn't take it for a spin. When you hit the gas, it'll vibrate your head with the windows shut! I've never ridden in a NASCAR car, but I've been to a few races and I'm betting that's what it sounds like! I'll gladly answer any questions if anyone has any. Thanks for reading!
    • Like Like x 5
    • Winner Winner x 4
    • Useful Useful x 3
  2. cole3986
    cole3986 Gold Member
    Apr 25, 2015
    1,827
    949
    563
    Lawrenceville, NJ
    Nice write and good job. Sounds nasty good. o_Oo_Oo_Oo_O
  3. Angel
    Angel Gold Member
    Aug 19, 2015
    1,423
    859
    413
    League City, TX
    Sounds great wish I could hear it in person. Did you notice any lack of power driving with them open? Keep us posted with the ground clearance.
  4. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    No loss of power at all that I can tell. It actually seemed to pull harder, but that might have been a product of the auditory orgasm...:D:D
    • Funny Funny x 6
  5. Supercharged_Fun
    Supercharged_Fun Gold Member
    Jun 25, 2015
    917
    368
    Sounds pretty damn nasty! I like it.
  6. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,895
    1,313
    498
    Virginia
    Sounds great!
    Adds new meaning to the term WOT! WOT&E
    (edit) No better help than self help!
    Great job and thanks for posting pics!
  7. MaxxMuscle
    MaxxMuscle Gold Member Hellcat Car Club HCC Charter Member
    Feb 10, 2015
    723
    291
    Lafayette La.
    Great job OP.
  8. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    Thank you, Sir.
  9. Zebug
    Zebug Gold Member
    Nov 11, 2014
    2,793
    966
    628
    Houston Texas
    very cool, I'm so envious of those of you that have the space and knowledge to do stuff like this. Maybe once I get a house I'll be able to play more (living in an apt post divorce so aren't even allowed to work on cars in the parking lot)
  10. Ray Hunsaker
    Jan 26, 2015
    598
    197
    I installed mine about a month ago, I love the sound but only for a short time real hard on your ears!!!!! I did the remote and that I love. not a bad install but a pain in the ass when your old,fat,and its on jack stands lol. and I swear it feels that it pulls harder but like the op said might be just in my head. i would love to dyno to find out.
  11. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    Can I ask how much gap you ended up with at the front connection of the pipes, if any? I cut mine where it said to cut them, so I followed the directions to a T.
  12. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    I definitely don't claim to have any extraordinary knowledge but I can follow directions well...although my 3 ex-wives might disagree. :D
    One more note, I had taken my car into the dealer for its annual inspection on Saturday and asked the tech about the best way to remove the center console and he printed out a couple pages from their online manual that was SUPER helpful. That was honestly my biggest concern. I didn't want to damage the interior of a $70k car!
    • Funny Funny x 2
  13. Ray Hunsaker
    Jan 26, 2015
    598
    197
    so like on yours only one side had the cut mark, had to wing it on the other side but really no biggie.as far as fitment sliding the pipe into the rear pipe was and is tight I would of liked it in farther but because of that I didn't have any gap.OH by the way varoom varoom. lol
  14. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    Yeah if I'd closed the gap completely, I wouldn't have been comfortable with how much was inserted in the back. I know they can't fall out with the way they are so I'm good with it.
  15. Paladin06
    Sep 3, 2014
    4,923
    2,044
    818
    San Tan Valley, AZ
    Awesome job. Thanks for sharing.
