OBDII Flash tune...
Discussion in 'SRT Hellcat Performance' started by Driver72, Oct 27, 2015.
  1. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,204
    276
    Is there any chance for one with the Hellcat or does it's rolling codes render that impossible?
  2. rayzazoo
    Nov 8, 2014
    3,198
    1,141
    668
  3. Driver72
    Mar 10, 2015
    1,204
    276
    Thanks, but that's what I don't want to do.
    I'm wondering if their will ever be a OBDII port flash, like nearly every other car, that you can flash yourself and then flash back to stock if/when you want/need.
    I would not want to pull out the PCM and replace it with another. Too easily caught by dealer computers and if I'm not mistaken, vehicle info (odometer, etc) will no longer match between PCM boards.
  4. rayzazoo
    Nov 8, 2014
    3,198
    1,141
    668
    It could be a possibility, however, if some of the leading aftermarket tuners are finding the solution is to swap the PCM or unlocking the stock PCM and use a tuning device, I think that will be the solution for 2015+.
    Chrysler will be happy with this kind of solution because it makes aftermarket modification easily detectable and it reduces the risk of warranty fraud.
