Octane booster.
Discussion in 'SRT Hellcat General Discussions' started by Ford killa, Jan 16, 2016.
  1. Ford killa
    Ford killa Silver Member
    Dec 1, 2015
    242
    98
    178
    What brand of octane booster do you use or do you use in at all?
  2. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    On a stock cat just a good grade 93 is all you need, haven't seen any data to prove other wise...
    TC
  3. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    myth buster
    TC
  4. Catscratch Fever
    Catscratch Fever Silver Member
    Jul 10, 2015
    603
    112
    I think the manual says not to use octane boost products.
  5. slester1
    slester1 Silver Member
    Jan 13, 2015
    352
    86
    Yeah but wouldn't an Octane booster eliminate the bad gas effect? Pulled timing = HP
  6. Mills
    Mills Silver Member
    Jan 28, 2015
    775
    194
    Airdrie, Alberta
    a better test would be in an actual octane tester, but it shows if you don't need it, it won't help
    I use Aces IV in my Charger all the time. I use it for the lubricating properties to deal with the ethanol in the gas, but it eliminates the slight timing pull I was seeing
  7. Ford killa
    Dec 1, 2015
    242
    98
    178
    Not sure if it's really busted if i don't put some in my lingenfelter Z06 corvette it will ping ...
  8. NorCaletch19He77Kat
    Aug 30, 2015
    966
    297
    173
    waste of time and money--but it does smell good.....
  9. carcass
    carcass Silver Member
    Sep 7, 2015
    858
    267
    173
    snake oil
  10. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    That's because the vette was most likely tuned for better gas, I doubt Lingenfelter just put a CAI on it and pasted a logo on it.
    TC
  11. TNCHARGER
    Nov 19, 2015
    1,219
    478
    408
    I read another test on octane boosters that measure the octane. Most of the boosters did boost octane but only by points not numbers. Points is tenths while number is whole. If a booster says it will boost by 3 points then the octane will go from 93 to 93.3 This what most boosters actually do.
    In the test I read only Lucas and Torco increased the numbers. I can't remember for sure but I think Lucas increased from 93 to 97. Torco went from 93 to 99.
    One thing to remember is octane basically just increases the temp needed to ignite fuel. If your engine is not tuned for higher octane you may loose power as shown in the video posted earlier.
  12. Speedman
    Speedman Silver Member Hellcat Car Club
    Feb 18, 2015
    413
    178
    Maple Grove MN.
    Just switch it to E85
  13. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,018
    491
    403
    Westchester
    There is no knock at 93 octane in hellcats. Hellcats are tuned for 91 octane.
  14. Catless
    Catless Silver Member
    Feb 2, 2015
    1,044
    217
    198
    Parkersburg, WV
    I plan to datalog the Cat this spring/summer with my Trinity and watch for knock retard. When I datalogged the 09 SRT in really hot weather here, I found I had to use about 95 octane to eliminate most knock retard. I did that by mixing Sunoco 100 with 93 octane. Unfortunately we have no source for the unleaded race gas now.
  15. Catless
    Feb 2, 2015
    1,044
    217
    198
    Parkersburg, WV
    Have you datalogged to verify that?
aces iv
aces iv octane booster
octane booster
octane booster hellcat
torco octane booster dodge charger
