OEM 20 x 9.5 wheels weigh....
Discussion in 'SRT Hellcat Wheels and Tires' started by Driver72, Mar 31, 2015.
  1. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,216
    281
    28.8 lbs each.
    I've seen posts that say they weigh mid 20's, others as high as "just about 33 lbs" and a couple in between.
    So my 12 day old Hellcat was put up on a lift, pulled off the right rear tire/wheel.
    The combination of the two weighed 62.8 lbs
    Tirerack lists the OEM Pirelli P Zero Summer Tires as 34 lbs. (granted it could be 34.3 lbs, it could be 33.8 lbs, who knows which way they rounded).
    So it's safe to say the stock wheel weighs between 28.5 and 29 lbs.
    • Useful Useful x 2
  2. B5 Blue
    1,745
    Thanks!
  3. IA_Cat
    IA_Cat Silver Member
    Oct 22, 2014
    150
    49
    We have four of these that were purchased for resale. I just opened one up. A wheel alone is 26.06 lbs. Keep in mind this is without lug nuts or a center cap.
  4. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,066
    649
    413
    So Cal
    Sounds about right for a forged wheel ;)
  5. Driver72
    Mar 10, 2015
    1,216
    281
    That seems too light. Not sure if your scale is off.
    The "shipping weight" of the tire and wheel combo is 64 lbs.
    I weighed the wheels and tires, minus the lug nuts, but with center cap and a couple tack on wheel balancing weights and it was 62.8 lbs. Tried it several times, placing them on the scale in different directions, same each time. Seems right considering the box and foam in the shipping would add a pound or two.
    So with lug nuts, 29 lbs seems accurate.
  6. IA_Cat
    Oct 22, 2014
    150
    49
    Part of the wheel must have been touching the first time. I just reweighed the boxed wheel and it was 32 lb 7 oz. Then I weighed just the box, It was 3 lb 14 oz. So that means the wheel is 28 lb 9 oz. I did this twice and was within an ounce both times. Hopefully this info helps someone.
  7. Driver72
    Mar 10, 2015
    1,216
    281
    That's what I've been saying in my original post, and i knew your first numbers were off. They are 28.8 lbs each. ;)
  8. IA_Cat
    Oct 22, 2014
    150
    49
    Yep, you pretty much nailed it.
  9. VanishingPoint
    VanishingPoint Gold Member
    Jan 6, 2015
    1,023
    259
    258
    Somewhere, Texas
    Thank you again Driver72. I love when folks provided hard facts when they get the chance to do so. Like many people, if looking to purchase aftermarket, I like to go of solid facts to know if I am getting my $$$ worth,
  10. 1FSTCAT
    1FSTCAT The Punisher
    Dec 28, 2014
    1,130
    408
    358
    Virginia
2015 charger srt wheels weight
are hellcat wheels lighter than srt8 wheels
hellcat rim weight
hellcat wheel weight
hellcat wheel weights
hellcat wheels weight
how much doe stock hellcat wheels weigh
weight of hellcat wheel
