Oil Change Observations
Discussion in 'SRT Hellcat Maintenance' started by All2Easy, May 6, 2016.
  1. All2Easy
    All2Easy Senior Hellcat Member
    Apr 20, 2016
    53
    33
    Just did my first oil change on my Challenger HC....835 miles
    Couple of observations...
    1. The drain bolt on the oil cooler was finger tight....did not need my 15mm wrench to loosen.
    2. I wish the oil cooler itself was somehow better secured to the chassis, and check the lines going to the cooler itself. One of them rubs up against a pretty sharp metal edge of the support structure around it. As the oil cooler is fee to move a bit or vibrate separate from rest of the car, I could imaging over time the metal could potentially wear a hole in the line. I put some heat shield wrap around the line to better isolate it from the structure.
  2. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    Thanks for the heads up. I am going to change my HC oil for the first time this weekend.
  3. Steven_sbs
    Steven_sbs Browncoats Unite Gold Supporting Member
    Dec 18, 2014
    899
    379
    South Jersey
    Did you remember there are two oil drain bolts?
  4. slester1
    slester1 Silver Member
    Jan 13, 2015
    352
    86
    When I changed my oil the oil cooler bolt was also "loose" but not leaking. All done though and 6qts exactly filled it to the top of the cross hatching indicator on the dipstick.
  5. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,486
    4,835
    963
    Make sure you drain the second plug for supercharger. There shouldn't be a lot of oil but it is necessary to change
  6. Catscratch Fever
    Catscratch Fever Silver Member
    Jul 10, 2015
    603
    112
    The second plug for the supercharger? There are only two drains for the engine oil, normal oil drain plug and oil cooler.
  7. All2Easy
    Apr 20, 2016
    53
    33
    Yep
  8. Jungle Cat
    Jungle Cat Gold Member
    Feb 24, 2016
    1,141
    276
    258
    A couple more to add from my first change. My oil cooler bolt was not super tight but was just about right. I used a large adjustable wrench on the square block when removing and tightening the line bolt to avoid putting stress on the line. The oil filter on mine was put on by Hercules. I still got it off. Nice to know old Herc could not get the better of this old guy. The new filter just went on as tight as I could get it by hand like I always have. It took 6.5 qts to fill mine like other guys have mentioned here. I wish this was not so but it is. I wonder if there are different suppliers for dipsticks and tubes which may give you a different reading? You would figure all other parts like oil pan etc would be the same so why the difference?
  9. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    Did you check your oil when it was hot? Cold oil can show about a pint low...
  10. MattG
    MattG Gold Member Hellcat Car Club
    Mar 12, 2015
    880
    493
    Allentown, PA
    I got about 10 ounces out of the cooler location when i did my charger.
  11. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,895
    1,313
    498
    Virginia
    10 to 11 ounces from oil cooler
  12. Robocop1127
    Robocop1127 Silver Member
    Aug 26, 2015
    393
    118
    Pittsburgh,PA.
    Ebay has 7qts plus the 05038041AA SRT Oil Filter for only $56.58 plus only $10.05 shipping which includes Canada as well!!! Just put in Penzoil 0W40 Platinum and do a search & it will come up under the vendor (kingscjdparts) (Amazon have great deals as well!!!)
  13. Teo
    Teo Judge Yooper
    Jun 7, 2015
    905
    448
    Yooper Land
    Hey Robo,
    Check with your dealer about a cost + 10% program for you! :cool:
  14. Teo
    Teo Judge Yooper
    Jun 7, 2015
    905
    448
    Yooper Land
    12oz's to be exact! :)
  15. Robocop1127
    Aug 26, 2015
    393
    118
    Pittsburgh,PA.
    Hey Teo, my dealer is actually a good long time friend of mine and I even have 5 free oil changes but I always do my own oil changes and just can't bring myself to letting their guys touch my car unless I meet them in person first. I still only have 19 miles on mine due to the worst spring weather here in Pittsburgh!!! I hope all is well with you my friend and tell your wife hello and for her to enjoy her day,ttys,Robert
