Oil Cooler Drain Plug Drip - UPDATE!
Discussion in 'Dodge Challenger SRT Hellcat' started by WNY Cat, Apr 10, 2015.
  1. WNY Cat
    Nov 16, 2014
    581
    375
    513
    I decided to install my Big Mike's Sto-N-Sho front license plate mount this morning so I removed the belly pans and came across this...
    I wiped off the drain plug and I figured that the plug was loose so I'll just snug it up. I put a socket and 3/8" ratchet on it and I couldn't tighten it at all so now I'm left to wonder if it was over tightened or cross threaded. I'm going to leave the plastic pans off for now to see if another drip forms on the plug.
    At this point it's only sitting in storage so I don't expect to figure it out anytime soon.
    No. I didn't get the plate holder installed yet. I'll start another thread about that later.:)
    • Useful Useful x 2
  2. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    70.196059, -148.559760
    Let us know when you figure it out. It's a fragile setup IMO. The aluminum block that the plug scres into is threaded. When you screw the plug it it just feels tight and easy to cross thread I'm sure. I'm definity replacing that plug with a valve at next oil change. Already ordered the parts.
  3. Paladin06
    Sep 3, 2014
    4,789
    1,945
    818
    San Tan Valley, AZ
    I was there when they dropped my plastic pans to change the oil and no drips. Keep us informed.
  4. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    Probably should have a dowty seal, or at least an O-ring/fiber washer.
  5. magnummrk
    magnummrk Platinum Member
    Sep 30, 2014
    3,826
    1,113
    918
    Wisconsin
    Keep us posted!
  6. TallCool1
    2,438
    829
    Pacific NW
    Google or Amazon search boat inspection plates, boat deck covers etc. for example below. Many shapes sizes, clear, etc. you can get
    them for thin wall applications.
    Cut out belly pan and plastic aero covering wherever you want to install. Clear ones will give you visibility. And these can give you access to to perform service work without removing a ton of stuff but still seal for aero dynamics.
    Done this before haven't on Hellcat yet just throwing out there having 1 or 2 placed for your personal goals might also be good to visually see fluid issues like this.
    Shop around can be found cheaply.
    Amazon.com Clear screw - Vents Deck Plates Boat Cabin Products Sports Outdoors
  7. Brampton Builder
    Brampton Builder Gold Member
    Dec 13, 2014
    434
    310
    513
    Yikes , these fittings come to the plant pretorqued and we just install them. So they are not checked by the plant. Hopefully your tightening it fixes this issue
  8. WNY Cat
    Nov 16, 2014
    581
    375
    513
    I'm planning to change the oil soon so I will inspect the threads and seat when I take it out. I'll probably replace the drain plug and/or the seal anyway.
  9. WNY Cat
    Nov 16, 2014
    581
    375
    513
    Brampton Builder SRT_HC_707 magnummrk Paladin06 HCone
    I changed my oil last weekend (at 650 miles) and found why my oil cooler drain plug was dripping. There was a metal chip caught in the seal area. I took some close up photos and you can see the damage that it caused to the seal surface and the seal itself.
    With the metal chip removed it has stopped dripping. I'll show the photos to my dealer and see what they suggest.
  10. fnkychkn
    Jan 24, 2015
    1,546
    648
    greasy cardboard box
    yup, that'll do it.
    you can try filing it flat and using a new drain plug, or replacing the cooler.
  11. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    When I changed my oil a few long aluminum shavings from the tapping process came out with the plug. After the oil flowed out I cleaned up best I could with the wooden side of a large swab. I just don't like how this oil cooler drain is setup.
    I would take those photos to the dealer and explain what happened. Maybe they will warranty the cooler. If they won't warrant I would do as fnkychkn suggested. Plug that hole with a something and file that entire surface flat. Then maybe sand it smooth and get a new drain plug.
    I just hit 1150 miles last night. I'm thinking of doing my next oil change at 1500 (500, 1500 and then probably every 3K to 5K after that). I've got an oil drain valve (EZ Drain) ready to go with my next oil change. I think I"m definitely going to put that on so I'm not messing with the threads etc... I think it is great that they have a drain to get this low spot but I wish they engineered it a bit better. If you have any interest in putting a drain valve on there I put some details in the WIKI section. Both Fumoto and EZ Drain make them. I've used Fumoto in the past but went EZDrain this time. I thought it was better because it had nickel plating over the brass and used a viton o-ring seal vs. a fiber washer on the fumoto.
    I did check my oil yesterday right before I went to a cruise night and so far mine hasn't used any.
  12. B5 Blue
    1,745
    Hurry up and put the dang thing in before I get my car so I know all went well and to get one:D
  13. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    350 ish miles to go. Won't be long....
  14. B5 Blue
    1,745
    But it will only lose a few ounces then you can recheck after the 350 miles:D:D
  15. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    If I didn't have to pull the belly pan off I would have done it already. Not that it's hard but rather a PIA!
2015 dodge challenger hellcat oil cooler
2015 dodge challenger srt hellcat oil drain
dodge challenger hellcat oil cooler drain
draining pd oil cooler
oil cooler drain plug hellcat
oil drain plug challenger hellcat
remove pan belly challenger 2015
