Oil Cooler Leak
Discussion in 'SRT Hellcat General Discussions' started by dodgeboy16, Nov 2, 2015.
  1. dodgeboy16
    dodgeboy16 Hellcat Member
    Feb 10, 2015
    80
    10
    My oil cooler is leaking at the fittings (both). Anybody else having this problem. Now the bad part, not all of the parts are available. I had this problem with my 05 SRT-10 and used after market lines to fix the problem.
    Jack
  2. SUPERCOOLSRT
    SUPERCOOLSRT VIP Hellcat Member
    Nov 18, 2015
    128
    66
    98
    Huntington Beach, ca
    . Same issue look Familiar?
    What was your reaolution to this?
    Dealer said the same thing that all the parts already have a driving the car seems to be running OK haven't really been pushing it
    Seems like it's leaking at the fitting as well
    Dealer tech called it a seep not a leak
    Apparently better
    I have 1000 miles on the car at about 600 miles I noticed the issue when I went to go do it oil change at Valvoline the guys let me know there was an issue. Did not change oil yet.
    I didn't want to mess sitting for the oil filter and listen anything up
    Oil pressure was around 37 psi at 600
    Miles Now it goes in between 34-35 at idle when in Drive at a standstill.
    No leaking on the floor at all or in the pan
    wondering if the decrease in oil pressure is also because there's less oil in the car now as overtime oil percentage is now 85 %
    Seems logical
    Though
    Thanks
    Rob
  3. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,267
    372
    Newport, MI
    Mine is the same as well. Also had seeping around oil pan drain plug and oil filter....
  4. dodgeboy16
    Feb 10, 2015
    80
    10
    Rob,
    When the Tech. fixed mine he replaced both the lines and the Cooler itself. It seems to me that the Shity Fittings are the problem. Run your HC hard like at the Track and I'll bet you will find enough "seeping" to cause a drip.
    Jack
  5. SUPERCOOLSRT
    Nov 18, 2015
    128
    66
    98
    OK thanks for the answer I appreciate that I won't run it hard until they get the replacement part I'm just really njoy the car
    Daily driver so no need to beat on it right now I did enough of that with my jeep SRT At the track.
  6. SUPERCOOLSRT
    Nov 18, 2015
    128
    66
    98
    Do you have any of the part number that were ordered?
    My rep was telling me they were not even made yet..lol
    Ok I said I'd check w my team
    Aka u guys
    Thanks
  7. dodgeboy16
    Feb 10, 2015
    80
    10
    Sorry no, but I know the parts were put In I saw them. The SRT people helped find the parts.
    Jack
  8. SUPERCOOLSRT
    Nov 18, 2015
    128
    66
    98
    No sweat
    By the way I went back to Valvoline today to have my guys there to check and see if the oil filter area still see thing and it wasn't it all looks like the tech at Dodge cleaned it up the other day, must have tightened something because I put 400 miles on the car since Friday and there's no oil leaking
    they still have the parts on order so obviously they thought there was an issue but car is running great so were all good here
    Thanks
  9. dodgeboy16
    Feb 10, 2015
    80
    10
    Run your HC a little hard I bet it will Seep.
  10. SUPERCOOLSRT
    Nov 18, 2015
    128
    66
    98
    Yes I'm sure it will
    Don't want it to until I get replacement parts on
    Thanks
hellcat oil cooler fittings
hellcat oil leak fitting
