Oil cooler on SRT 392?
Discussion in 'Dodge Charger SRT 392' started by 16SRT, Apr 4, 2016.
  1. 16SRT
    16SRT Silver Member
    Feb 20, 2016
    422
    122
    So much info on Hellcats, right down to videos of oil changes... not so much for us SRT 392 owners.
    First oil change coming up. I've seen all sorts of discussion of draining the oil cooler (separately) on the Hellcats, but see no evidence of a separate oil cooler when peaking thru the lower grille of the SRT 392. What's a little surprising, if there is none, is that the SRT 392 spec's a quart MORE oil than the Hellcat... not less.
    Can anyone state with authority whether or not the SRT 392 has an oil cooler which should be drained during oil change?
  2. TNCHARGER
    TNCHARGER Gold Member
    Nov 19, 2015
    1,221
    480
    408
    The 392 does not have the oil cooler that needs to be drained..just the HC...I own both...
    • Useful Useful x 2
  3. 16SRT
    16SRT Silver Member
    Feb 20, 2016
    422
    122
    Thanks! Any guess as to why the 392 takes a quart more oil?
  4. TNCHARGER
    Nov 19, 2015
    1,221
    480
    408
    Not really sure why one less qt. You would think with the cooler and lines it would require more. I assume the crankcase pan is maybe smaller though the reduction may be due to the beefier block of the 6.2...
  5. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    3,059
    1,520
    498
    Virginia
    From 5.7l/6.1l configs to the 6.1l/6.4/ all hemis have used 7 quart pans. Extra volume of oil helps keep the motor safe in a bunch of ways.
    Hellcat decided on oil cooler to offset lower oil volume in the pan.
  6. MABBRYFL30
    Feb 10, 2016
    7,958
    5,587
    1,163
    7 quarts
  7. ciphros
    ciphros Gold Member
    Mar 13, 2016
    1,093
    561
    613
    Tri-cities WA
    Also due to higher heat loads from forced induction.
  8. 16SRT
    16SRT Silver Member
    Feb 20, 2016
    422
    122
    "Beefier block"? I thought they were the same block, albeit populated with different heads and supercharger. Dodge marketing states Hellcat also has forged crank and pistons, but they're unclear on the crank and pistons in the SRT 392.
    I've not seen any literature that states they're different blocks, but I'll admit I haven't read it all. In any case, oil capacity is dictated by pan, not block.
  9. Toolman_42
    Jan 26, 2015
    3,059
    1,520
    498
    Virginia
    Last scribblings I recall had engine at 90% rework to be able to withstand addition of supercharger . Lots of updates...even displacement changed to a 6.2l
  10. TNCHARGER
    Nov 19, 2015
    1,221
    480
    408
    The blocks are different. The beefier block could dictate the size of the pan...just a shot in the dark since I don't know why 6qts instead of 7...
    The 392 has a forged crank but not the pistons and rods....
2016 charger srt 392 oil cooler
2017 charger 392 srt oil cooler
first oil change 2017 charger 392 srt
