Oil cooler quick drain solution
Discussion in 'SRT Hellcat Maintenance' started by SRT_HC_707, Apr 8, 2015.
  1. SRT_HC_707
    Jan 1, 2015
    4,919
    1,420
    70.196059, -148.559760
    When I changed my oil recently I wasn't crazy about the oil cooler drain setup. It's an aluminum line with a block of aluminium that is drilled and tapped for a drain plug. Nothing really supports the line.
    You definitely need to support the boss where the plug screws in or you risk possibly twisting, damaging or breaking the line.
    I was thinking a Fumoto valve or EZ Drain would be a good idea. I didn't think to measure the drain plug when I had it out but DrBuick did and he states the drain plug is 12 x 1.75 x 25 (12mm diameter, 1.75 thread pitch and 25mm thread length).
    I was looking around and found a good site for EZDrain Welcome to OilDrainValve.net authorize online dealer of EZ Oil Drain Valve. I think I like the EZDrain better than Fumoto because EZDrain has a viton o-ring seal rather than a fiber washer (but either valve is excellent and pretty much the same. Difference is EZDrain has the o-ring and it is nickel plated over the brass housing).
    Here is the parts list of what I'll probably get. Only the first item is required. The others are optional depending on what you want.
    • EZ-107 (12mm x 1.75 drain valve)
    • Small saftey clip (not required but I'd get this. It's a spring clamp that is a second protection against the valve opening. These valves will NEVER just open. You would have to hit them on something first. If you hit this you have bigger issues as you just wasted the front end of your car!)
    • L-001 90 degree elbow (just to direct oil flow easier)
    • 3/8" cap plug (only if you get L-001.. It's just a dust cover)
    • 3/8" vinyl hose (It's a 3 foot piece. You can use any 3/8 hose. Just used to direct the oil flow. This will allow you to use one drain pan while draining both engine and cooler. You need the L-001 to attach the hose)
    Here is what the EZDrain looks like. This type of valve has been around forever and they are used in many industrial applications. They are well made and don't leak/fail. The valve locks closed in the detent and a spring holds the lever there. The secondary clip also makes it so the valve can't be accidently pushed up but this really wouldn't happen in this application.
    [​IMG]
    • Winner Winner x 4
  2. B5 Blue
    1,743
    Good stuff thanks!
  3. SRT_HC_707
    Jan 1, 2015
    4,919
    1,420
    B5 Blue since we have confirmation from DrBuick on the measurements of the drain plug I created a WIKI entry for this item.
  4. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,381
    768
    Slinger Wisconsin
    I checked them with mine out lol
  5. B5 Blue
    1,743
    Super! One more thing I need for my car when it's built thanks!
  6. IA_Cat
    IA_Cat Silver Member
    Oct 22, 2014
    150
    49
    Great! I will order this. Wondering if I should do the same for the oil pan. I change my oil outside and the wind often blows the oil around. Which fittings would be used for the oil pan?
  7. SRT_HC_707
    Jan 1, 2015
    4,919
    1,420
    DrBuick provided the following measurements
    Oil cooler is 12x1.75 1 inch long
    Oil pan is 14x1.5 3/4 inch long both from seal to end of plug
    If you look here Size Chart - EZ Oil Drain Valve the EZ-106 is the right one for 14x1.5
  8. LForst
    LForst Driver of Badassery
    Oct 29, 2014
    511
    264
    California
    Fr
    That's an awesome idea
  9. Deputydog
    Deputydog Gold Member
    Nov 2, 2014
    1,002
    260
    Spokane, Washington
    Hmmmmm.. I happen to have an F-106 on the shelf (same size as my duramax) that I haven't yet installed. I was planning on doing my first oil change today on my Cat so I'll report back if the F-106 works on the oil cooler.
  10. SRT_HC_707
    Jan 1, 2015
    4,919
    1,420
    Deputydog Have you changed your oil? Curious if the F106 worked on size-wise for the oil cooler drain plug replacement.
    I've got another change coming up in 350 miles but be nice to verify size with someone who has done it.
  11. SRT_HC_707
    Jan 1, 2015
    4,919
    1,420
    Looking again though the cooler drain is the F or EZ 107. I think you might be doing the pan rather than the cooler?
  12. JonWrong
    JonWrong Silver Member
    Feb 3, 2015
    358
    51
    Orlando, FL
    Don't bother with the EZ-drains. I bought one or the oil pan and the cooler. Bother will not fit as the clearance for the top (switch) side will not allow you to tighten them down. You could get the EZ-drain on the cooler line if you removed the line from the cooler itself. The oil pan one would also go on if the pan was out of the car. But installing them in place will not work.
  13. JonWrong
    Feb 3, 2015
    358
    51
    Orlando, FL
    And FYI: the 107 model threads fit the oil cooler drain; the 106 threads fit the pan. You just cannot tighten them down due to clearance. I took a pic and can post later.
  14. IA_Cat
    Oct 22, 2014
    150
    49
    I already ordered mine. I sure hope I can figure out a way to make them work. I'll be trying in a few weeks.
  15. JonWrong
    Feb 3, 2015
    358
    51
    Orlando, FL
    Well, don't stick your head in the sand. I have been working on cars a long time, and I know what I am talking about. Here are pics of the two areas and where the top part of the EZ will hit before you can get them tight. The one for the oil cooler line hits almost immediately.
    [​IMG] [​IMG]
2015 dodge challenger hellcat oil cooler
draining oil cooler 2015 challenger hellcat
hellcat oil cooler
how much oil drains out of the oil cooler on a challenger hellcat
how to drain oil from oil cooler on a dodge hellcat
oil cooler location on a chellanger hellcat
oil drain plug challenger hellcat
