Oil leak 2 days after delivery
Discussion in 'Dodge Challenger SRT Hellcat' started by Markp, Jun 4, 2016.
  1. Markp
    Markp Gold Member Hellcat Car Club Gold Supporting Member HCC Club Member
    Aug 5, 2015
    2,307
    1,080
    498
    Ontario, Canada
    Hey guys I picked up the Hellcat 2 days ago I have 350kms. I have been following the recommended break in procedure. Moved the car today found 2 spots of oil roughly 3 inches apart and each around 2 inch in diameter. Has anyone had this happen? I will take some pictures tomorrow and I will try to find where the leak is coming from. I will also check the oil level.
  2. sublime6spd
    sublime6spd Gold Member
    Nov 2, 2014
    853
    488
    Ontario Canada
    Are you certain its oil??
    My guess is it's soot from the exhaust.
    All cars drip from drainage weep holes near the joint in the exhaust.
    They Stop doing it once carbon is built up inside exhaust system.
    Hopefully you Don't have an Oil leak.....
    Double check ;)
    Mine made two spots on the garage floor the first couple months but no longer does.
    • Useful Useful x 2
  3. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    412
    Approximately where under the car did you find the residue?
  4. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,514
    1,433
    818
    Endless Mtns of Pa
    its common for spots of black condensation from the exhaust to be mistaken for oil
  5. SUPERCOOLSRT
    SUPERCOOLSRT VIP Hellcat Member
    Nov 18, 2015
    128
    66
    98
    Huntington Beach, ca
    Yes I've had a "seep" the dealer called it from the plastic connector fitting from the oil line going to the oil filter
    No pressure loss from this for me
    Average is 34 -39 at standing idle
    And depending on how you have the steering wheel turned it go little lower times
    A seep rather than a leak nothing dropped down to the floor as maybe urs did.
    This seep just sprays out intermittently spraying oil on filter. "Damaged part is white part" u can see yellowish color being oil in the pic
    It took the parts a few weeks to come in, was on back order.
    Here is a pic
    Hope this helps
    I am found out about it because I went to my first oil change on the skid plate
    If it turns out to be a leak
    Call the Srt hotline
    Tell them nicely this is unacceptable and u would like there help
    Let them call dealer while ur in the line closest to u w a specified SRT tech
    Let them do the appt for u keep them in the loop like I did
    Dodge gave me a few oil changes free
    Of course I had to ask for it..
    Remember dealer will give u nothing go thru SRT directly
    Let me know how it works out
    Cheers
    • Useful Useful x 4
  6. Hellcatmichael
    Hellcatmichael SRT Hellcat Supporter Gold Supporting Member
    Oct 20, 2015
    1,024
    315
    Can you see the filter from under the car without removing anything ? Can't see it from the top.
  7. Robo21
    Robo21 Gold Member
    Mar 13, 2016
    969
    508
    368
    So Cal
    Okay, I need to follow up with you. I have the same weeping or seeping oil which is not like a drip, more like a misty leak. I want to follow your route to repair, I like the idea of getting a few oil changes for the inconvenience. Did you arrange for the free oil changes through SRT or the dealer?
  8. Markp
    Aug 5, 2015
    2,307
    1,080
    498
    Ontario, Canada
    Can't find the leak I need to put it on a hoist.
  9. Markp
    Aug 5, 2015
    2,307
    1,080
    498
    Ontario, Canada
    Also I had to put a liter of oil in the car after 375kms. I called the dealer they said they are calling SRT.
  10. Catless
    Catless Silver Member
    Feb 2, 2015
    1,044
    217
    198
    Parkersburg, WV
    ^^^That is soot from the exhaust.
    • Agree Agree x 7
  11. Markp
    Aug 5, 2015
    2,307
    1,080
    498
    Ontario, Canada
    I hope so but need to make sure it's not something else.
  12. Catless
    Feb 2, 2015
    1,044
    217
    198
    Parkersburg, WV
    20151026_133031.jpg Cat_crap.jpg That will be dry after is sets for a while. Oil puddles never dry up.
    If you look behind the car, you will probably find where the same black soot blows out the exhaust when you start it.
  13. CanHP
    CanHP Silver Member
    Mar 23, 2015
    323
    123
    Mississauga Ontario
    Yep
  14. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,657
    925
    Suwanee, Georgia
    This is car popping .. Get a CAT litter lol
  15. Slowpoke387
    Slowpoke387 Gold Member
    Jan 31, 2016
    1,809
    542
    423
    Enfield, CT
    Yep my brand new 16 went in to my mechanic at about 1000 miles for an oil change and i was told there is oil coming from the oil cooler area. Nothing on the ground so i didnt notice it. Possible fitting leak. Havent brought it in yet but man, its disappointing to say the least.
    Wonder if the dealer did the change, if they wouldve even noticed. This is why i use my own mechanic unless its warranty related.
