P2227
Discussion in 'SRT Hellcat TSB's' started by hemiguy, Apr 20, 2016.
  1. hemiguy
    hemiguy Silver Member Hellcat Car Club Gold Supporting Member
    Aug 9, 2015
    256
    96
    Vermont
    I had/have a problem with my 15 hc, engine light came on and through a code p2227, barometric pressure sensor and went into limp mode. Long story short, I cleared code and dealer can't do anything until it happens again.they need to get a freeze frame,whatever that is,and send to srt. Apparently the pcm will have to be replaced. There is a tsb out on this issue. If this happens to any of you beware. You may want to check with your dealer to see if this will affect your car. Since clearing mine it runs great but I'd hate to be 100 miles from home when it happens again.
  2. carcass
    carcass Silver Member
    Sep 7, 2015
    857
    263
    173
    Has it happened again?
    Did your dealer change the PCM?
    My car threw the code, but for a reason, my buddy took off in fifth gear while racing another car.
  3. hemiguy
    Aug 9, 2015
    256
    96
    Vermont
    It hasn't happened again so no new pcm yet
  4. currybob
    currybob Bob
    Jul 17, 2015
    1,021
    506
    Alexandria Alabama
    Would that not show up in the monthly report? I opened my account which is free and get a monthly status report. Part of that report shows if any codes have been thrown.
  5. JeffL
    JeffL Silver Member
    Feb 9, 2016
    197
    73
    178
    mine thew this code once. my finger slipped off the start button just as it started or was about to start and it started really hard. the idle sort of hung around 2k then it went into limp mode threw the code and the check engine light. There was a TSB posted here (can't find it now) all it said was for the dealer to do was record the incident, reset the ECU and disconnect the battery for at least 30 seconds.
    I disconnected the battery all was clear and now it's been 2 or 3 months no issue or recreation.
  6. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,540
    590
    423
    I only press my start button just long enough for the computer to know I did. Like I would press the door unlock button. Just a quick tap.
  7. Sawdust
    Sawdust SRT Hellcat Supporter Gold Supporting Member
    Mar 13, 2016
    115
    52
    198
    Green Lane, PA
    That does not work on our HC, you have to hold it in, maybe a M6 thing.
  8. JeffL
    JeffL Silver Member
    Feb 9, 2016
    197
    73
    178
    must be a M6 thing you need to hold the button until it starts.
  9. Code3100
    Code3100 Silver Member Hellcat Car Club
    Sep 6, 2015
    259
    85
    178
    Mine threw that code plus 2 others, replaced a faulty Crank Shaft Sensor though.
what does code p2227 on a 2016 challenger hellcat
