PCV SUCKS / C.C. Evac. Mods.
Discussion in 'SRT Hellcat Maintenance' started by TallCool1, Sep 18, 2015.
  1. TallCool1
    2,439
    829
    Pacific NW
    I am trying to understand PCV mount. The PCV comes out easy. I am trying to get down to bare metal on the cylinder head cover. And to do that if I need to remove the cylinder head cover itselt (which I hope is not the case.) Does anyone know? I can't tell on Tech Authority. fnkychkn anyone?
  2. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,623
    702
    greasy cardboard box
    not understanding what it is you're trying to accomplish.
  3. TallCool1
    2,439
    829
    Pacific NW
    I want to remove pcv that's easy rotate 90 degrees it's out. Appears there might be a plastic housing / mount (whatever you want to call it) remaining (unsure) that would still be in cylinder head cover. That might be threaded like a piece would be inside. I need to remove everything so I'm to bare metal on the cover. Not just the pcv but also the mount. I haven't tried anything yet on my car to know when I remove the pcv does everything come off so I am to metal on the cover do you know?
  4. TallCool1
    2,439
    829
    Pacific NW
    Here's a pic. If you look close, there's a nut around and the pcv is separate from that. The pcv also has a index that sit's inside the nut so the center piece doesnt rotate seperate from the nut. I thought to remove pcv it was rotate 90 counter clockwise then pull it out. You can't rotate the center pcv by itself easy because of the index that goes into nut slot.
    When I rotate the entire nut / assy turns. I did that 90 degrees but the assy almost seems threaded. I became concerned that if I kept going that something might be on the inside of the cylinder head cover that would drop inside so I tightened it back and bailed and wanted to check if anyone knows can I take it all out like I was doing without something falling inside , if that makes sense.
    Thanks Pete (or anyone who knows.)
  5. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,483
    473
    408
    The Boonies
    nope cant help you but I sent you a PM.
  6. TallCool1
    2,439
    829
    Pacific NW
    I got it out (it was threaded not 90 degree twist lock just screws into cylinder head cover) all good proceeding onward.
    • Useful Useful x 2
  7. TallCool1
    2,439
    829
    Pacific NW
    And it's shot as I suspected :mad: oh well it will be swapped out Monday when I change the rear end with the 3.09 unit.
  8. fnkychkn
    Jan 24, 2015
    1,623
    702
    as usual, i'm late to the party. lol
    these are the parts available:
    [​IMG]
    [​IMG]
  9. rayzazoo
    Nov 8, 2014
    3,877
    1,584
    818
    So #3 in the picture is the PCV valve? And what we are looking to do here is remove the valve completely?
  10. TallCool1
    2,439
    829
    Pacific NW
    No. It's a total piece of crap though and this type is going bye bye from my car likely fast.
  11. cole3986
    cole3986 Gold Member
    Apr 25, 2015
    1,827
    949
    563
    Lawrenceville, NJ
    what do you mean shot, when you shake it is rattles and thus is not sealing properly?
  12. TallCool1
    2,439
    829
    Pacific NW
    It sucks. Rattle doesn't tell u much that can go either way working or not (it can still stick.) You'll see soon, I'm drilling it out and re locating a different one that will ne integrated into my catch can mount. That I can tune. Along with changes to the make up side that will negate the need or concern for catch can there. It'll be a trick setup way more flow (under pressure), more stable vacuum, tunable based on rpm all sealed filtered and I'm banking on a change in performance (done this before.)
    • Useful Useful x 2
  13. cole3986
    Apr 25, 2015
    1,827
    949
    563
    Lawrenceville, NJ
    Ok I am with you, like where you are headed, please keep us posted ;););););)
  14. TallCool1
    2,439
    829
    Pacific NW
    Yup it'll be a much better crank case evacuation setup than stock. Will keep in touch adios
  15. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    Have a beer and relax you think too much about going faster ;)
    • Funny Funny x 2
5038793aa
air bleed mod from pcv
hellcat pcv check valve
hellcat pcv filter
pcv mod check valve setup
pcv valve on 2016 hellcat
