Picture Of Engine/Cooler Schematics?
Discussion in 'SRT Hellcat General Discussions' started by VanishingPoint, Mar 1, 2015.
  1. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    975
    249
    Somewhere, Texas
    Has anyone found one? I am primarily looking for the system of oil/water coolers, and their locations.
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    Ummm, say what????
  3. B5 Blue
    1,745
  4. fnkychkn
    Jan 24, 2015
    1,544
    648
    greasy cardboard box
    from FSM:
    [​IMG]
    The Low Temperature Radiator (LTR) cooling system is a closed secondary system that regulates charge air cooler operating temperature.
    • The system must be vacuum filled.
    • The LTR system has a 18 psi reservoir cap, the engine cooling system has a 21 psi reservoir cap.
    • The LTR system uses a 250 watt electric coolant pump.
    the main LTR is located between the AC condenser and the HTR (high temp rad).
    the auxiliary LTR is located behind the fascia where the left fog lamp would be.
    the charge air cooler coolant pump is located just above the auxiliary LTR.
    the engine oil cooler is located behind the fascia where the right fog lamp would be.
    • Useful Useful x 2
challenger hellcat charge air cooler thick
cooler operating system
hell cat teansmission coolerband engine cooler
hellcat cooler
