Pin me
Discussion in 'SRT Hellcat Performance' started by shakenbake, Jul 3, 2016.
  1. shakenbake
    shakenbake Gold Member
    Apr 29, 2016
    151
    136
    493
    Peice of cake. Removed the lower radiator bracket then dropped the fan. Too easy. image.jpeg
    • Like Like x 9
    • Winner Winner x 4
    • Useful Useful x 2
  2. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,296
    649
    413
    PASADENA, CALIFORNIA
    What kit did you use? I hope you were able to knock that upper pin down flush before you installed the bolt/washer. I am sure you did because the pic is flawless and in perfect focus etc. Nice job!
  3. shakenbake
    Apr 29, 2016
    151
    136
    493
    I did its flush now. Picking up a new bolt tomorrow. It's a bwoody kit
    • Like Like x 3
  4. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,665
    928
    Suwanee, Georgia
    You got good eyes ;)
  5. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,665
    928
    Suwanee, Georgia
    that's what I thought when I saw 2 pin, it has to be bwoody kit.
  6. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,665
    928
    Suwanee, Georgia
    If you don't mind, can you please take picture of exactly bolt or part did you remove. I've never done this pinning and was wondering if I can do it myself or not.
  7. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,296
    649
    413
    How do you keep the crankshaft from turning when you loosen and tighten /torque the bolt?
  8. shakenbake
    Apr 29, 2016
    151
    136
    493
    Removed the rear inspection plate and wedged a pry bar in the flywhee.
    • Useful Useful x 4
  9. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    Very clean
    What kinda drill did u use and what kind of drill bit?
  10. yellaheep
    yellaheep Gold Member
    Jun 13, 2016
    222
    114
    Littleton Colorado
    Is there is a thread or two that describes the problem this is solving? I assume it's that the balancer moves on the crank? Why isn't this a warranty issue?
  11. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,296
    649
    413
    If the balancer spins on the crank it "is" a warranty issue. But it requires a new engine to be installed. Most people do not want an engine replacement.
    If it spins because of mods done to the motor then your warranty is void.
    If I mod my engine, I definitely WILL pin my crank and I like this double pin method.
  12. shakenbake
    Apr 29, 2016
    151
    136
    493
    I used the drill bit supplied with the kit and a air power angle drill. I removed the fan and propped back the radiator with some wood block then covered it with some cardboard to keep it from being damaged and started drilling
    • Useful Useful x 3
  13. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,665
    928
    Suwanee, Georgia
    I heard that you have to remove fan and removed lower rad support to make it work...
  14. shakenbake
    Apr 29, 2016
    151
    136
    493
    Exactly what I did
  15. rwhite692
    rwhite692 Gold Member
    Jul 17, 2015
    653
    263
    Central Valley, Northern California
    For those of you that have done this, when installing the new crank bolt, are you installing with the bolt threads "dry", or are you applying any lubricant? I was thinking to apply a very small amount of the ARP thread lube that they supply with their fasteners....?
