Pinning the Crank Pulley
Discussion in 'SRT Hellcat Builds' started by zippy, Nov 6, 2015.
  1. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    134
    Ontario
    Decided it is the right thing to do especially with an upper pulley change.
    I have done one before on my 300, so I am familiar with the process and I do have a pinning kit from the old 6.1 platform that I think will work based on what I have read.
    I would appreciate any insight from anyone who has done this on a charger ?
    It looks like I can get to it with a 90 deg drill as long as I remove the fan housing.
    It also looks like the fan assembly has to come out of the top. I can't see it fitting by removing it from the bottom. Perhaps fnkychkn has some insight on removal of the fan assembly?
    Thanks for any insight . . . . .
    PS - This is how my 300 ended up
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    Is the done while still being on the car?? Or is it a bench top mod??
  3. hellcat1
    Sep 27, 2014
    10,672
    2,033
    I want to say cole333 May being doing his add we speak...he had spon two pulleys so far
  4. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    411
    I've done it in a '13 SRT Charger.
    Pull the fans.
    Unbolt the radiator and tilt it back a bit.
    I used a cordless angle drill.
    It's not fun but it can be done.
    I wouldn't imagine the Hellcat to be much worse
  5. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    134
    Ontario
    Thanks
    I have done one the same way.
    I actually got the fans out and backed off the rad. There is room with a right angle drill except I can't get the crank bolt out for the life of me.
    I think it's time to put it back together and re-group
    Ps - I have a new crank bolt ready to go in..
    Uuugh
  6. YLWJKT
    Oct 12, 2015
    411
    Can't get it out as in can't get it loose?
  7. FarAwayFromHere
    FarAwayFromHere Gold Member
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Throw some heat to her,if you do make sure to wrap a wet rag or cloth around the pulley so you control the heat to the pulley,just heat the bolt....Carefull....
    And Use An Impact Gun with an impact 6 point socket & no reducers if at all possible!
  8. Robert7
    Robert7 Silver Member
    Dec 20, 2014
    133
    52
    178
    Washington
    I had a hard time getting my 5.3L LS crank bolt out. It took two people, one pulling and one pushing, and an extra long breaker bar.
  9. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    134
    Ontario
    Thanks for the tip
    I usually put a breaker bar, pry it on the floor and jog the engine with the starter. Rotation is opposite and it works. Never had a problem.
    This time, no dice.
    I can't turn it by hand with the breaker bar because the engine spins and I don't know how to stop it from spinning on an automatic.
    Frustrating..
  10. Lord Hellcat
    Jan 6, 2015
    1,627
    741
    UK
    Use the gearbox pull under the centre console and stick it in drive. That should work
  11. YLWJKT
    Oct 12, 2015
    411
    I don't know if the Hellcat pulley has it, but on the 392 pulley there's 2 x 10mm threaded holes.
    I took 2 long shouldered bolts and threaded them in and used a pry bar to hold the pulley from turning. Then I used a breaker bar and cheater pipe to break it loose.
    Did the same thing on reassembly to torque it.
  12. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    134
    Ontario
    Thanks YLW!
    When I was looking there is in fact 3 holes for a pulley remover and they had threads in them
    I will find a couple bolts and use a pry bar from prevent rotation, Damn, wish I would have thought of that then.
    I put the car back together last night in frustration. Will tackle another day....
    Thanks for the tip !!
  13. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,562
    517
    273
    Albany NY
    "PS - This is how my 300 ended up"
    Just curious why did you pin it twice?o_O
  14. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    134
    Ontario
    keep the pulley balanced as I used roll pins per Kenne belle instructions
    The fixture had 2 holes in it.
    While I was at it I did both pins . . . . .couldn't hurt I suppose
    thanks
    zip
  15. Hemi Rocket
    Sep 27, 2015
    1,562
    517
    273
    Albany NY
    Ok Makes sense... I just hadn't seen that. If KB says to do both... that is what you do.
hellcat crank bolt tips
hellcat crank pin kit
hellcat crank pulley
hellcat pulley removal
hellcat pulley thead right hand
pinning crank on hemi same kit as ls
pinning crank pulley on hellcat
