Pirelli Zero 285/40 R20
Discussion in 'SRT Hellcat Wheels and Tires' started by BKuz, Nov 9, 2015.
  1. BKuz
    BKuz Retired American Fighting Man
    Oct 22, 2014
    1,324
    597
    Weeki Wachee, Florida
    I have looked on multiple tire vs rim charts and the largest tire that can safely be put on a stock Hellcat rim is 285/40 R20. Why did Dodge only put 9.5" rims on the back of the Hellcat? Every other muscle car has 315 or 325 tires on the rear or larger with 10.5" to 11" rims.
    BKuz
  2. Johnny Popcorn
    Johnny Popcorn Hellcat Member
    Dec 20, 2014
    91
    14
    Pretty sure that a 295/40/20 will fit. I went to tire rack and it appeared that a 295 would fit. That 295 came up when I did the search for other tires. Right now, my plan is to put the 295's on. Where did the 285 come from?
  3. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    The reason they went with 275 40 20 at all four corners is so owners can rotate there tires,, and not having any rubbing issues in the front going around corners...it's in the video with Jay Leno from this time last year...hope this answers your questions
  4. BKuz
    Oct 22, 2014
    1,324
    597
    Pirelli P Zero
    Tire Size: 295/40ZR20/XL
    Service Description: 110Y
    Sidewall: Black Sidewall
    Material Number or MSPN: 1743900
    Rim Width (min. to max.): 10.0 - 11.5
    Section Width: 11.9
    Overall Diameter: 29.3
    Tread Depth (32nds): 10
    RPM: 688
    Max Load (lbs.): 2337 lbs @ 50 psi
    It shows a minimum of a 10 inch rim.
    BKuz
  5. DGatzby
    Jan 16, 2015
    3,533
    1,871
    748
    Twin Cities, MN
    Same thing with 305's, people are mounting them on the 9.5" rears. The issue is you need to make sure the wider tire won't rub the suspension up front, even if you mount it. Let us know.
  6. BKuz
    Oct 22, 2014
    1,324
    597
    It looks like in order to safely put wider tires on the back of the Hellcat you will have to buy larger rims such as 10.5" or 11" rim. I was hoping to keep using the stock rims. Is there a rim out there that looks almost identical to the stock black matte Hellcat rims, that will fit without modifying the wheel well? I know you have to have the proper offset or the tire will rub.
    BKuz
  7. Lighty
    Lighty Silver Member
    Dec 20, 2014
    773
    173
    Ontario
    Replika wheels
  8. BKuz
    Oct 22, 2014
    1,324
    597
    Lighty,
    Thank you for the tip! I will check it out.
    BKuz
  9. Lighty
    Dec 20, 2014
    773
    173
    Ontario
    You are welcome Sir,
    I got a pair for my MT 305s 10 wide
  10. Hellcathopefull
    Hellcathopefull Hellcat Member
    Jun 15, 2015
    48
    9
    I'm planning on going with the 295/40R20 Pirelli P Zero on the stock rims. I can deal with a little taller sidewall, but a shorter one will give me fits. Just trying to find a good side view image of the 295/40's on a Cat. The 305's are too much of a chance on width and the gap/height in the fender is a little much for my liking..
  11. BKuz
    Oct 22, 2014
    1,324
    597
    Lighty,
    Did you have to do any modifications? Do you having any rubbing? Did you get the matte black? Sorry, for all the questions, but I am very interested in these rims. I know what I want for Christmas. You can buy the SRT center hubs and replace the blank generic ones and it will almost look like stock Hellcat rims.
    Thank you again for the tip!
    BKuz
  12. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,216
    281
    Just so it's clear, going to 285/40 street tires will gain you nothing in acceleration.
    Going to 295/40 street tires on the stock rims will only make your car accelerate slower.
    And both will make your car handle worse.
  13. Milspec
    Milspec Silver Member
    Feb 15, 2015
    206
    43
    Care to explain your reasoning? I dont believe you are correct as well when you change width to 295 0r 305 you would need to go from 40 to 35... so the proper size that would actually fit is 295 35 20 or 305 35 20 (rear) ...295 setup will fit front only. Anytime you have more rubber on the road its a good thing.
  14. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,503
    877
    Suwanee, Georgia
    I've been reading old thread and noticed that so many fellow members have run 305 Nitto or MT 305 without any problem in stock rim
  15. BKuz
    Oct 22, 2014
    1,324
    597
    Specifications
    Pirelli
    P ZERO
    • Size: 305/35ZR20
    • Service Description:(104Y)
    • Load Range: SL
    • UTQG: 220 AA A
    • Max Load: 1984 lbs.
    • Max Inflation Pressure:51 psi
    • Tread Depth:8/32"
    • Tire Weight: 31 lbs.
    • Rim Width Range:10-12"
    • Measured Rim Width:11"
    • Section Width:12.3"
    • Tread Width:10.6"
    • Overall Diameter:28.4"
    • Revolutions Per Mile:732
    • Country of Origin:GERMANY
      ITALY
    • Size: 305/35ZR20
    • Load Range: SL
    • UTQG: 220 AA A
    • Tread Depth:8/32"
    • Tread Width:10.6"
      ITALY
    For rim width it says 10 to 12 inch rim. I don't see 9.5 mentioned anywhere.
    BKuz
2014 charger with 285 40 20 tires
285 40r20 nitto for challenger
285 70 r20 charger
285-40 r 20 vs 275-40 r20
challenger 285 size rear on 11 inch wheel
charger 305 tires
hellcat 295 tires all four
pirelli 1743900
