Poll--Who Has Had Leaking Radiator/hoses
Discussion in 'SRT Hellcat TSB's' started by currybob, Sep 23, 2015.
Who has had leaking radiator ?
  1. Had leaking radiator
    29 vote(s)
    33.0%
  2. had leaking radiator hose
    9 vote(s)
    10.2%
  3. Not had any radiator type leaks
    56 vote(s)
    63.6%
Multiple votes are allowed.
  1. currybob
    currybob Bob
    Jul 17, 2015
    1,027
    508
    Alexandria Alabama
    Think we are having too many of these occurrences and losing idea of the count or how many this is effecting.
  2. rw99
    rw99 Silver Member
    Feb 13, 2015
    80
    178
    Castro Valley, CA
    I checked "hose", but it could also be the radiator... in any case, I had the first work done (for the clamp), but I still get an occasional little puddle of coolant via the passenger side weep hole in the lower cover.
    So it's going in next week for the radiator.
    Rich
  3. currybob
    currybob Bob
    Jul 17, 2015
    1,027
    508
    Alexandria Alabama
    Rich
    Just the kind of info I'm looking for but you didn't put you vote in the poll to be counted.
  4. DGatzby
    Jan 16, 2015
    3,560
    1,885
    748
    Twin Cities, MN
    We found just a bit of antifreeze under the left corner of the radiator on a recent oil change. Took pictures. Then took it out for a day of abuse hitting over 150 mph at a race track, oil temps were over 260, but she recovered fine and no problems. I will continue to watch the suspicious area.
    How about the power steering fluid spraying all over the left valve cover after a few good laps?? Anyone having this?
  5. MoparPhil
    MoparPhil Gold Member
    Feb 15, 2015
    174
    148
    413
    Provo, Utah
    I get mine back today after the radiator is replaced. Started out as a spot of fluid on the ground and got progressively worse. Turns out it was a leaking seam on the radiator. Easy fix. Something for others to watch for.
  6. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    my rad replaced
  7. yurdaddy
    yurdaddy Silver Member
    Mar 5, 2015
    325
    100
    Motor City
    I had a rad, water pump, all hoses, starter , two grounds replaced Then they took the top of the motor off and replaced the gaskets and put longer head bolts in since the heads were lifting up off the motor at full throttle causing coolant to blow all thru the engine compartment. Fca finally agreed to swap my car out for a new one.
  8. DB2
    DB2 Silver Member
    Feb 4, 2015
    342
    83
    Are you frigging serious!?!?!?! WOW.................
  9. nkdave
    nkdave Sublime, black hood, M6
    Feb 8, 2015
    117
    38
    Woodland, Washington
    I had my "O" ring blow out from the back of my water pump a few months back. They replaced it, no problem. The next week my power steering fluid cap blew off, spraying fluid on my engine. I found the cap and one of the tongs was broke off. Now my engine smell of antifreeze after I drive it hard (all the time.) no fluid loss that I can see, not sure where it's coming from. I'm keeping an eye on it.
  10. DGatzby
    Jan 16, 2015
    3,560
    1,885
    748
    Twin Cities, MN
    Thanks, I think I will bring it in for them to look at. It is a cheap POS anyway. Seemed like the fluid was just appearing, everything looked in order was the strange thing. Then like you say, when I got home after exercising it, I smelled antifreeze. We have the same things exactly happening!
  11. nkdave
    Feb 8, 2015
    117
    38
    Please keep us posted what they find. It will be awhile before I can get mine in for repair. We definitely are not the first to have this problem, hopefully There will be a better radiator coming out soon! Have a great weekend.
  12. ranger75
    ranger75 Silver Member
    Jan 12, 2015
    165
    54
    Have not had rad leak yet. But my car does fall in the range of VIN's stated in TSB. I have had the rad clamp TSB done when it came out in April/May time frame. My dealer stated they KNEW about the radiator at that time and they say they checked it. I called BS since the revised TSB was not released till August. They looked my VIN up and said it is not showing (as the TSB states it should) as needing checked. In the end I am taking it in end of this month for them to check it while I watch! I have no leaks as of now.
  13. rw99
    rw99 Silver Member
    Feb 13, 2015
    80
    178
    Castro Valley, CA
    Ahhh, but I did. "Hose"
  14. nkdave
    Feb 8, 2015
    117
    38
    I blew the "O" ring out of the back of my water pump. Drained my tank all over my engine, I stared a thread on it. Ever since I can smell radiator fluid after running hard after shut down. I have had time to take it to the dealer. I've neve had a puddle under the car. I do believe I have a radiator leak. Build date 6/19 build number 5009.
  15. der Arzt
    der Arzt Hellcat Member
    Aug 12, 2015
    47
    53
    18
    Rineyville, KY
    Hey, this is interesting. I had a whiff of antifreeze one time. Thought I was crazy. I checked, didn't see anything. Will keep an eye out.
