Power steering lost
Discussion in 'Dodge Challenger SRT Hellcat' started by WindowShaker, Apr 1, 2016.
  1. WindowShaker
    WindowShaker Gold Member
    Oct 1, 2014
    760
    428
    VA
    i was driving home tonight when my power steering went out. I noticed it when I stopped at a light. It seemed fine at higher RPM's but when I was at idle or very low RPM's, it was nearly impossible to turn the wheel and the pump was whining pretty loudly. When I got home, I couldn't see any leaks of any kind and the reservoir was full. Anyone else have this issue? I'm thinking the pump went out partially. Is this a Dodge issue? Any idea why it would suddenly go out?
  2. 1949chopper
    1949chopper NC STATE PRESIDENT Hellcat Car Club HCC Charter Member
    Oct 5, 2014
    1,463
    705
    563
    Gold Hill NC
    Lower pulley starting to slip maybe ?
  3. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    F*** I hope not
  4. Fastcat ny
    Fastcat ny Silver Member
    Aug 24, 2015
    157
    61
    178
    Not good ! !!!!!! I think 1949chopper might be correct .
  5. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    Everything else seemed ok. What other symptoms would the lower pulley cause?
  6. Fastcat ny
    Aug 24, 2015
    157
    61
    178
    Look where the belt contacts all pulleys see if anything has any excessive movement ?? Check belt tension at the ps pump ?
  7. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    Thank you. I will in the morning.
  8. Fastcat ny
    Aug 24, 2015
    157
    61
    178
    I think someone else here had the same issue and ended up being the crank pulley. What is the build date of you car someone on here is tracking that also with the pulley failures
  9. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    Early December 2014.
  10. 1949chopper
    Oct 5, 2014
    1,463
    705
    563
    Gold Hill NC
    Temps would go up and voltage would drop. But you wouldn't notice if it was just intermittent. The power steering would be instant though.
  11. Fastcat ny
    Aug 24, 2015
    157
    61
    178
    Hmmmmmm I don't recall any failures from that time I believe most are from May-June ? Hopefully is just something simple like a pump ?
  12. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    I watched the temps all the way home. No different than before. Around 202 to 207 while in traffic or sitting. 197 to 199 while driving.
  13. WindowShaker
    Oct 1, 2014
    760
    428
    VA
    Yeah I'm hoping
  14. 1949chopper
    Oct 5, 2014
    1,463
    705
    563
    Gold Hill NC
    That's good. Check lower pulley in am. May have a leak on suction side of pump causing some aeration or something. That could be why you see no drips
  15. 16SRT
    16SRT Silver Member
    Feb 20, 2016
    422
    122
    Nerves of steel. I'm betting most here wouldn't sleep with the thought of a spun crank pulley in the back of their head.
