Powerstop brake pads Z23 vs Z26
Discussion in 'SRT Hellcat Performance' started by SRT_HC_707, Jun 20, 2015.
  1. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    70.196059, -148.559760
    I'm just sharing some information I got from emailing Powerstop. I haven't used these pads yet. I'm running stock pads and I have no intention of swapping them out until the stock pads are worn out.
    I emailed Powerstop asking what the difference was between the Z23 and Z26 series pads for the Hellcat.
    Here is a quick summary of what they said in return.
    • Z23 and Z26 use the same friction material in the pad itself
    • They are both low dusting and will dust the same amount as they are the same friction material
    • Backing plate shim on Z23 is rubberized and backing plate shim on Z26 is stainless steel
    • The Z26 pad will tolerate higher heat due to the SS backing plate
    • Both pads are low noise but I would suspect that the Z23 may be even better in the noise department due to the rubberized shim (just a guess here)
    Both good choices for the Hellcat but the Z26 seems more appropriate to me and probably what I'll order if I try these over OE at my first pad replacement.
  2. B5 Blue
    1,745
    Good info and yeah rubberized will help squealing
  3. Max57
    Max57 Silver Member
    Apr 29, 2015
    338
    134
    Central Virginia
    I already have a set (front & back) of the Z23 on hand from when my SRT arrives.
  4. Srt8u
    Srt8u Silver Member Hellcat Supporting Vendor
    Mar 21, 2015
    725
    232
    Good info, we stock both varieties, but the Z23 is the more popular choice so far for the HC
  5. Jim M
    Jim M SRT Hellcat Supporter Gold Supporting Member
    Jan 12, 2015
    615
    214
    Oviedo, FL
    My Z23's arrived a little while ago but I have not installed yet. My car only has 1,800 miles and I can already feel a slight ridge on the rotors. The stock Brembo pads eat rotors and they aren't cheap. I'll swap in the Z23's very soon and hope they are more rotor friendly.
  6. Dubai-707
    Dubai-707 Hellcat Member
    Jul 18, 2015
    43
    5
    Which one do you recommend z23 or z26 pads and rotors combo.
  7. R3dk3y
    R3dk3y Hellcat Member Hellcat Car Club Gold Supporting Member
    Apr 28, 2016
    94
    15
    I have the Z26 pads up front on my Charger, and I put them on after about 3 weeks of taking delivery. I couldn't stand the dust on my car, as it's a daily driver, and 1 trip to/from work and I'd have to re-clean the wheels. There is zero squeal / noise with the Z26 pads. If you do frequent heavy start / slow downs, I would assume the higher temp rated Z26 pads would be a better choice.
  8. dueling glove
    dueling glove Silver Member
    Oct 5, 2015
    134
    28
    Hi, hey guys do you suggest to use the Z2X package rotors as well? If so which kit? I think the Z26 1405 fits our HC Chargers, correct?
  9. Jim M
    Jan 12, 2015
    615
    214
    Oviedo, FL
    I can't think of a reason you'd need new rotors at this point. Maybe in a few years and a bunch more miles. Meanwhile the factory originals are just fine.
  10. dueling glove
    Oct 5, 2015
    134
    28
    Thx Jim, that's what I thought but my HC tech told me to get them changed out soon, before summer and those suckers aren't cheap. Only the front he said and I am looking to change the pads to Z26 and get OEM or a better rated rotor. I already had to change out the tires and would like another option besides the P-Zeros. I'm at 19k miles, I've been driving this thing a lot. Any suggestions?
  11. Jim M
    Jan 12, 2015
    615
    214
    Oviedo, FL
    My past experience with an '08 Challenger was that the Brembo pads had eaten all 4 rotors by 40k miles. They were worn below limits for turning. So I replaced the rotors and the pads with Hawk ceramic pads. Those ceramic pads needed a lot more pedal pressure but they didn't eat the rotors like the Brembos did. On my '15 Charger HC I replaced the Brembo pads with the Z23's at about 700 miles. I now have about 9k miles on the HC and I can't feel any ridge at all on the stock rotors. And I feel no difference in pedal pressure or stopping power. Time will tell but I think you will be as happy with the Z26's as I am with the Z23's. I think I would have my rotors turned if I weren't replacing the Brembo pads until 19k miles.
  12. dueling glove
    Oct 5, 2015
    134
    28
    Wow. My technician said you can't turn these rotors. I'll ask him about it though. I'm past 19k miles now
  13. Jim M
    Jan 12, 2015
    615
    214
    Oviedo, FL
    That could be, I don't know. Maybe one of our more enlightened members will know. I'd trust any info from Fnkychkn.
  14. oilburner
    oilburner Gold Member
    Nov 23, 2015
    247
    103
    coboconk ontario
    you can`t machine grooved rotors.
  15. Roostking
    Roostking Silver Member
    May 14, 2015
    788
    164
    When you say grooved, what exactly is that? I know it sounds obvious enough. My 392 has 50,000 on it, original pads and the rotors have a lip around the outer edge. Does that mean they will need to be replaced?
power stop z16 vs z23
power stop z23 vs z26
power stop z23 vs z36
power stop z26 review
power stop z26 vs z23
powerstop z23 vs z26
powerstop z23 vs z26 difference
z23 vs z26
