Problems with 315s
Discussion in 'SRT Hellcat Wheels and Tires' started by Noquarter, Jun 6, 2015.
  1. Noquarter
    Noquarter Gold Member
    Nov 19, 2014
    774
    249
    Columbus, OH
    I put new rims and tires in my cat this weekend. I went with a wheel called drag dr 64 with nitti motivos front and rear. Front tire is stock size 275/40 and the rear is a 315/35. The new rims are 10" in the back.
    My car had the p zero nero all season on it originally.
    The issue is the car feels very floaty now when accelerting. Its a bit disconserting to be honest. I was expecting it to be twice as grippy and better feeling than the o zero neros.
    Im thinking about going back to stock set up. I was just wondering if anyone else had experienced this? Its crazy that an all season felt way more stable than these nittos.
    Also it feels like the rims are a bit heavier than the stock but it could be the weight of the motivo wheels as well. Could that be a factor?
  2. RoRo
    RoRo VIP Hellcat Member
    Apr 11, 2015
    421
    107
    73
    Gilbert Arizona
    I have been looking for some summer tires but now you're scaring the crap out of me
  3. Noquarter
    Nov 19, 2014
    774
    249
    Columbus, OH
    I dont think its "summer" tires as much as the 315s maybe? I dunno it just feels weird
  4. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,216
    281
    Any shimmy in the wheel?
    Any noticeable uneven-ess?
    Who did the balancing?
    A few pounds here and there in overall weight won't even be felt in a car that's this heavy and powerful.
    In actuality, if your new wheels and tires were a few pounds heavier, they'd probably feel more stable than floaty.
    And also, the Motivo's are an all season tire too. They may just be more floaty than the P Zero Nero's
    The 315 size should have nothing to do with it.
    However, 315 size tires are recommended to have a 10.5 inch wide wheel too.
    It's marginally better than putting the 305 size tire on the stock 9.5 inch wheel, but not by much.
    So you maybe getting a tiny bit of ballooning and that may add to the floaty feel as well, but in that case I'm not sure, as people putting 305 tires on 9.5 inch wheel haven't reported it feeling floaty due to ballooning.
  5. Noquarter
    Nov 19, 2014
    774
    249
    Columbus, OH
    Sorry they are Nitto Invos not Motivos.
    I had them rebalanced today and it did help a little bit with some vibration. But not the floaty feeling. No real noticble shimmy in the wheel.
    Its just the car seems to track funny under hard acceleration, floating would be tue best description that comes to mind.
    I thought 10.5 as well but he said his notes that a 10" was the smallest.
  6. ArtOfNoize
    ArtOfNoize Silver Member
    Sep 24, 2014
    268
    94
    Toledo Ohio
    I run the 315 nitto invo on the rear but they are on 11s. No issues at all. The 305 555s run great on the 11s as well.
  7. Lord Hellcat
    Jan 6, 2015
    1,627
    741
    UK
    Maybe their sidewalls are a lot softer than the Pirelli's
  8. SinisterKitty
    SinisterKitty Silver Member
    Dec 6, 2014
    348
    Houston, TX
    I am running the 305 Nittos on the stock rim and I am not experiencing any floatiness due to ballooning. Do you think tire pressure has anything to do with it?
  9. Bascadog
    Bascadog Silver Member
    Mar 15, 2015
    424
    177
    Southern Ca
    I have done Nitto 305 555r's on stock rims and on aftermarket 10.5's. Never a problem.
  10. B5 Blue
    1,745
    SinisterKitty is right lower your tire pressure 5 lbs each or get another guage to compare the two.Go with 30 pounds cold and see what happens.
  11. Noquarter
    Nov 19, 2014
    774
    249
    Columbus, OH
    I believe they are softer sidewalls.
  12. Noquarter
    Nov 19, 2014
    774
    249
    Columbus, OH
    Could it be the invos on the front causing the tracking issues? Maybe alignment?
    I will lower the preassure 5lbs on the rear and try it out
  13. IA_Cat
    IA_Cat Silver Member
    Oct 22, 2014
    150
    49
    I have 315 Invos on 10.5" rims and have not experienced your symptoms. Hope you get it sorted out.
  14. hellcat562
    hellcat562 Silver Member
    Jun 4, 2015
    421
    151
    Anyone tried 315/35/20 on the rear with our OEM rims?
  15. Birddog
    Birddog Silver Member
    Mar 24, 2015
    166
    82
    178
    Your Nitto's/ Mickey Thompson Drag Radials will have a softer sidewall that will cause a little more "sway". These tires are designed more for the traction of straight away pulls and not touring/ cornering. I recommend that if it makes you feel uneasy of the ride, run your P-zero's for daily driving and the Nitto's when you want to go play. Or keep driving them and after a bit you will get used to the feeling of the 315 and just play all the time- :)
    • Funny Funny x 1
315s on a hellcat
315s on hellcat
charger on 315s
putting 315s on the hellcat
