Problems with Wheel hop
Discussion in 'SRT Hellcat General Discussions' started by FireLane, Jan 23, 2016.
  1. FireLane
    Jul 23, 2015
    394
    115
    Palm Beach County, FL
    Is anyone else having problems with wheel hop? I have a 2016 charger hellcat with Nitto drag radials on the back. Best time so far has been a 10.98 at 125. The few times I've been to the track I hook on my first pass (1.64 60') and then every other pass after that I get wheel hop and have to let out of it. I've tried launching at idle and various RPMs, with and without a burnout and it doesn't matter it just continues to wheel hop. I usually have the air pressure at 21 psi. I've already installed the speedlogix lower trailing arms. Any other ideas?
  2. blaze
    blaze ☆★✪ The Watcher ✪★☆ Hellcat Car Club Gold Supporting Member
    Dec 28, 2015
    2,024
    964
    498
    26.7100° N, 80.0500° W
    bump
  3. kenhebe
    kenhebe Silver Member
    Jun 24, 2015
    513
    119
    Drag radials must be heated up otherwise the sticky compounds in the rubber will not activate. Do not do a big smokey burnout as overheating them will make them greasy. Heat them up until you start to see a little smoke and then you are good. 21 PSI is high. Drop them down to 15 and see if they hook. If they do then raise the pressure in half pound increments until they don't hook. Keep in mind that even on drag radials a torque monster like this will still require throttle control. You want your tire pressures to be as high as possible while still biting off the line. Keep in mind that just a touch of wheel spin of the line is a good thing.
  4. kenhebe
    Jun 24, 2015
    513
    119
    Also, bump your front tire pressures up to 45 PSI. Set the suspension setting to street. Keep your traction control on until you get comfortable with it then set the traction control to track. It does not turn it off, but dumb it down.
2016 hellcat challanger wheelhops m6 forum
