Pulley change
Discussion in 'SRT Hellcat General Discussions' started by black06srt8, May 24, 2016.
  1. black06srt8
    black06srt8 Silver Member
    Apr 7, 2015
    149
    22
    128
    Ok so my buddy and I are wondering and I can't seem to find it why do you have to take the blower off to change the upper pulley is it a clearance issue because it looks like there is enough room
  2. Kado
    Kado Silver Member
    Dec 8, 2014
    141
    62
    178
    To be able to get the bolt off, if you don't then it just keep spinning
  3. DemonSkip
    DemonSkip Gold Member Hellcat Supporting Vendor
    May 2, 2016
    367
    239
    413
    Yep, it's fastened all the way through the snout.
  4. black06srt8
    Apr 7, 2015
    149
    22
    128
    thanks guys
  5. wewsrt8
    wewsrt8 Silver Member
    Nov 9, 2014
    187
    45
    Centerville, OH
    You can just lift the front of the supercharger up to get to the 3 bolts under the snout. That's what I did, it was not difficult at all.
    Good luck
  6. Mopar22
    Mopar22 Gold Member
    Jan 9, 2016
    227
    110
    New Mexico
    So your procedure did not include taking apart the windshield wipers etc...
  7. moparmangamble
    moparmangamble Gold Member
    Sep 7, 2015
    406
    264
    Yes, you still have to remove the wipers, plastic cowl panel and steel tube brace to get all the supercharger bolts out. It is very easy, go buy a tool to remove the plastic push rivets, that's the hardest part.
  8. rick arrieta
    rick arrieta Silver Member
    Oct 17, 2014
    226
    53
    I'm trying to get more info here,so when you change the upper pully do you have to get new belt or is there an ajustment mechanisium?
  9. moparmangamble
    Sep 7, 2015
    406
    264
    Go on HHP's website and look under the pulleys. You will need a new belt, tensioner only has so much range of motion. I have an ATI 10% over lower and 2.75" upper. I run the 594 belt. It gives guidelines on belts, any questions call HHP, don't email them, you won't get a response .
  10. wewsrt8
    Nov 9, 2014
    187
    45
    Centerville, OH
    Just as moparmangamble said
  11. Mopar22
    Mopar22 Gold Member
    Jan 9, 2016
    227
    110
    New Mexico
    o_Oo_O
    I have the 2.85 on my shelf , I am just hesitent to attempt this job.
  12. Link
    Link Silver Member
    Jan 27, 2015
    895
    206
    So someone said you need to change out the intake gasket, what is the part number for that??
  13. DemonSkip
    May 2, 2016
    367
    239
    413
    68271246AA
    Skip
  14. Link
    Link Silver Member
    Jan 27, 2015
    895
    206
    is it that one or the actual throttle body gasket or both that should be changed when swapping pulleys?
    THX
  15. DemonSkip
    May 2, 2016
    367
    239
    413
    Depends on the damage caused when pulling apart really. A lot of you guys have low miles so if you're careful you should be able to reuse the gaskets. As the year go on and guys are doing swaps with higher mileage HC vehicles, I would recommend new gaskets.
changing hellcat supercharger pulkley
hellcat challegner pulley change
hellcat pulley change
why does the supercharger need removed on hellcat
