Pulley Option
Discussion in 'SRT Hellcat Performance' started by Hell-Bent, Nov 24, 2015.
  1. Hell-Bent
    Hell-Bent Silver Member
    Jan 15, 2015
    224
    63
    I see some are using the Metco pulley and some are using the ATI pulley. When/Why would you use one over the other?
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    Some people are having issues with the crank pulley spinning off the crank.....should pin the crank if you do this mod
  3. Hell-Bent
    Jan 15, 2015
    224
    63
    Thanks hellcat1. Are there advantages to the crank pulley mod vs. the sc pulley mod?
  4. hellcat1
    Sep 27, 2014
    10,672
    2,033
    Metco is working on a kit to put a stock pulley on without removing the supercharger,, plus the metro upper pulley is half the cost of the ati lower pulley
  5. Hell-Bent
    Jan 15, 2015
    224
    63
    Makes sense. I guess performance wise they achieve the same with the proper tune?
  6. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,215
    358
    The ATI damper is a 2.6 drive ratio vs. the stock 2.38. The Metco pulleys allow up to about a 2.9 drive ratio I believe. More drive ratio, more boost.
  7. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    328
    176
    Our supercharger pulleys install with no modifications necessary, and the process is completely reversible if desired. Our pulleys are interchangeable, and allow for boost gains as high as 10 or 11 additional pounds. We also have a stock-diameter pulley ring available for those who wish to later return to the original boost level.
    Any pulley changes require the appropriate PCM revisions and proper-length supercharger belt. Pulley changes may affect your warranty.
    With regards to the balancer issues...I believe there have been about six documented failures, all on unmodified cars with the exception of one that had an aftermarket balancer that was not pinned. We are still collecting data to determine if there is a link among these cars (build dates?) with reported failures.
    • Like Like x 4
    • Useful Useful x 2
  8. Hell-Bent
    Jan 15, 2015
    224
    63
    Thanks Rick.
  9. TxBoosted
    TxBoosted Gold Member
    Jun 5, 2015
    132
    101
    278
    Tx
    Any black Friday deals going on?
  10. Rick@Metco
    Sep 7, 2014
    328
    176
    We are a manufacturer and our products are also available through a network of authorized retailers. It is our policy to refrain from special deals or promotions to avoid competing unfairly with them.
    We do allow our retailers some discretion with our pricing, so I suggest checking with them for Black Friday promotions. Several of our stocking distributors have have forums on this site.
  11. gto19
    gto19 Silver Member
    Aug 18, 2015
    521
    Is there anyone you can tell us who's selling your pulleys at a sale price?i need a 2.85 pulley :)
  12. zippy
    zippy Silver Member
    Feb 2, 2015
    358
    131
    Ontario
    IMO.....
    Metco's pulley price is really quite fair considering the quality and functionality of the item. I was very impressed with my 2.75 and also expect the same when my stock ring comes in.
    The costs are really in the ECU, tune, crank pinning, and driveshaft that you will need (in the case of an A8 for sure)
    I am all about saving, but the Metco stuff is reasonably priced IMHO
    Best Regards.
    zip
  13. gto19
    gto19 Silver Member
    Aug 18, 2015
    521
    Ya your right
    Is there any reason you went with a 2.75 over the 2.85?
  14. zippy
    zippy Silver Member
    Feb 2, 2015
    358
    131
    Ontario
    More boost. I am seeing 15-16lbs with good AFR's (11.7-11.8).
    HHP tune is quite good and the company is first class. I also have 94 fuel readily available in Canada.
    Still need to put in a shaft and run it down the track but the car is crazy fast and I am not seeing any ST or LT knock.
    In retrospect, the 2.85 would be a "safer" option for pump gas as I think the 2.75 is pushing the limits, but if you wanna play, expect the worst . . . . .
    just my .02
    best of luck on your setup
  15. upnorthstar
    upnorthstar Silver Member
    Mar 2, 2015
    483
    122
    Zippy did you do the crank pulley as well?....I think I'm going to go with the ATI crank pulley and the Metco 2.85" next Spring...
    Also where did you get the work done? in Windsor? me in Toronto...thanks
show pics of the ati hellcat crank pulley pin kit o
challenger hellcat ati crank
challengertalk metco pulley
hellcat stock pulley ratio
