Pullies
Discussion in 'Dodge Challenger SRT Hellcat' started by Dcrusing, May 31, 2016.
  1. Dcrusing
    Dcrusing Rookie
    May 23, 2016
    12
    2
    I have done the 3psi pully for the supercharger and I also want to do the super dampener for the crank shaft but is say further programming required
    Does anyone know about that
  2. rayzazoo
    Nov 8, 2014
    3,172
    1,135
    668
    If the damper is not the stock size, you'll need to tune again for the upper and lower pulley.
  3. Dcrusing
    Dcrusing Rookie
    May 23, 2016
    12
    2
    Do I need to tune if I only did the top supercharger pullie? I didn't see anywhere it said to do so.
    When I get the lower dampener what is a good tuner to use?
  4. Link
    Link Silver Member
    Jan 27, 2015
    830
    166
    yes, as the limit is set to like 11.6 psi. You won't benefit from the new one until tuned. Also some kind of fuel mixture change I believe. Call HHP
  5. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    315
    172
    Anytime the level of airflow through the engine is changed (like with the addition of a smaller supercharger pulley), the PCM must be revised accordingly. Otherwise, a dangerous lean condition could result.
  6. Dcrusing
    Dcrusing Rookie
    May 23, 2016
    12
    2
    Thx much
