Questions about procedure for long term storage
Discussion in 'SRT Hellcat General Discussions' started by FL 1st Hellcat, Apr 23, 2015.
  1. FL 1st Hellcat
    FL 1st Hellcat Rookie
    Feb 5, 2015
    24
    9
    Aside from the engine procedures that should be performed when mothballing the car for YEARS-(ie. removing the spark plugs, squirting anti-rust preservative into the cylinders, preventing any moisture from coming into the intake or exhaust manifold, etc.), this is more of a practical issue when "storing" the car for MONTHS (1-6?).
    Since I don't want to be faced with a dead battery after storing it as-is, in most cars with the battery under the front hood, simply disconnect the battery, lock the car, put the car cover over the car, and reverse the process, pulling the hood release cable to access the battery, and you're good to go.
    In the Charger, here's my problem-since the battery is in the trunk, and there is no external key lock to unlock the trunk, the only non-emergent way to unlock the trunk to get at the DISCONNECTED battery, is ELECTRICAL-either the pushbutton on the trunk lid, or the button on the dash-neither of which will work because of the lack of electricity.
    The only solution that I've come up with is to advance the front seats full forward, pull one (or preferably BOTH) rear seatbacks down to have access to the trunk, lock it up, disconnect the battery, close the trunk, car cover, then the reverse... unlock the front door with the key in the front door lock, and then crawl into the trunk and use the interior emergency trunk release. BTW-not easy to access the rear door locks when both front seats are full forward!
    I haven't tried it yet, but I guess I could pop the hood, and use the procedure for jump starting from the front of the car to supply electric current to open the trunk.
    Any other ideas?
    Regards,
  2. 707hpcharger
    707hpcharger Silver Member
    Feb 4, 2015
    236
    35
    Leave the battery in it and hook up a tender/trickle charger.
    or jump it like you stated.
  3. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,454
    957
    668
    Cape Coral, SW Florida
    You can open the truck and manually flip the locks latch into the locked position. Then lower the trunklid down. The trunk will be open a bit, but you could place a blanket over it and then the car cover on top.
    I use the latch trick to shut off the light so I can leave the trunklid open and trickle charge the battery without issue.
  4. B5 Blue
    1,748
    That's a six pack non fresh air air cleaner you got there
  5. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,037
    491
    403
    Westchester
    my long term storage: drive it everyday
  6. Lord Hellcat
    Jan 6, 2015
    1,637
    751
    UK
    Ideally hook it up to a trickle charger. CTek are about the best. They keep the battery conditioned.
  7. Aaron Vogel
    Aaron Vogel Gold Member
    Jan 23, 2015
    1,851
    331
    Everywhere
    i asked about this to, as i am routinely gone 3-5 months at a time. The only thing i found in the owners manual for long term storage is to run the AC for 5 min on high. On my next trip, 5 months, i will get a trickle charger and maybe the race ramps for tires, but thats about it.
  8. 707hpcharger
    Feb 4, 2015
    236
    35
    N96 FRESH AIR HOOD AIR CLEANER. ......on the 1969 roadrunner I sold only to end up here in VON hell!
  9. B5 Blue
    1,748
    Sorry to hear. Real A12 car? I kept mine;)
  10. 707hpcharger
    Feb 4, 2015
    236
    35
    Wasn't an A12. Just a factory N96, N85, V21, 3:91suregrip, 4 speed bucket seat sweetheart. I miss her...
  11. B5 Blue
    1,748
    Hope you get you new HC sooner than later
  12. Dragon
    Dragon Gold Member
    Oct 16, 2014
    658
    230
    AZ
    get some race ramps RR-FS that will help these soft tires from becoming flat spotted
  13. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,454
    957
    668
    My 08 Bee still has the original Mopar battery in it. How it's still going, I do not know. Must be the constant temp in the garage and limited usage
  14. Aaron Vogel
    Jan 23, 2015
    1,851
    331
    Everywhere
  15. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,149
    753
    628
    i would trickle charge it...and start it every 6 months, move the car 1' for the flat spots on the tires
    i wouldnt just abandon a new car and never touch it for years.....
can i disconnect my hellcat battery
