Racing Fuel VP MS109 question
Discussion in 'SRT Hellcat Performance' started by frank358fr, May 18, 2016.
  1. frank358fr
    frank358fr Rookie
    Mar 10, 2016
    20
    Hi Folks,
    I need to know the truth here. Is it worth putting VP MS109 racing fuel in my Hellcat. Will I gain power? I read that it should help the engine but does the 93 do the same job or the VP MS109 is really helping at the drag strip.
    My Hellcat is stock with Drag Radial only.
    Let me know
  2. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    It' doesn't hurt to put in a few gal of 109 to a 1/4 tank 93, fact is you really don't know what the 93 is so if looking for a good number why not.
  3. TNCHARGER
    Nov 19, 2015
    1,219
    478
    408
    What Top Cat said would be good safe guard against gas that isn't up to standards. Try it with race gas and without. If your 93 octane is up to standard and your not getting any spark knock the 109 may actually hurt performance.
  4. Lumpy53
    Lumpy53 Silver Member
    Nov 25, 2015
    361
    63
    Janesville wi
    It's the 93 octane that the car is tuned for so that's what I would use if you change to the race fuel get a tune with that fuel in it then you'll notice a big diff
  5. Link
    Link Silver Member
    Jan 27, 2015
    916
    208
    I thought I read somewhere on here where someone mentioned that mixing gas would not help as they do not truly mix together. 93 +91 does not equal 92 . So 106 and 93 would be the same, as I recall. You would just have pockets of 106 floating around in the 93 stuff. If this is wrong please correct me. I am just recollecting something I read on here.
  6. Lumpy53
    Nov 25, 2015
    361
    63
    Janesville wi
    I cannot answer that question I wouldn't have any idea but I know that gas stations mix your premium and regular to get a midgrade so yes you can mix fuel but I do not know about leaded and unleaded
  7. PlumTexasCrazy
    Oct 3, 2015
    2,427
    774
    308
    TEXAS
    Subscribed
  8. Link
    Link Silver Member
    Jan 27, 2015
    916
    208
    yea , I was just doing some internet research on mixing octanes and it says you can, so what I read before must have been incorrect, although I don't remember anyone ever disputing what was said. next time I will do my own research before trying to quote someone else, sorry. There are a lot of very sharp individuals on this forum, but I'm not one of them, lol.
    :oops:
  9. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    Gas does mix, even the leaded will mix with the unleaded.
  10. Lumpy53
    Nov 25, 2015
    361
    63
    Janesville wi
    Neither am I honestly I just trying to fit in
  11. Birddog
    Birddog Silver Member
    Mar 24, 2015
    175
    83
    178
    Frank, what you are basically achieving by mixing your fuel is to increase your octane level in a cost effective manner instead of 100% race fuel. As Link said mixing 50% 91 and 50% 93 does not equal 92. That being said by mixing 5 gal of 109 and filling the remainder of the tank with 91 would give you probably around an octane level of 96-97. From a performance perspective (even with out a tune) it will allow the computer to run max timing without retarding it due to ping (knock) thus resulting in more performance. The next thing that comes into play is weather (density altitude). If your running your car in Denver on a stock ECM, you probably will never see the benefits of this due to lack of air. But at sea level and on a nice cool day where the air is thick (good), this will allow your car to run to its maximum. But don't expect NOS effect here. I would expect that on prime runs (same location) on a track with a mix vs a straight 91 fuel you might see a difference of up to 0.05 et gain (ex. 10.90 with 91 and 10.85 with mix). You would probably see more gain between a good launch and a bad one and would really know which gave you the better ET, the launch or the fuel- LOL! That is the joy of EFI cars, they monitor how the motor is running to keep things safe. Days of carburetors, if you raced in Denver and had the car tunes just right, then traveled to Seattle for a race and left the tune the same, you would lean out pretty bad and would need better gas (octane and bigger jets). Lots of Racing 101 here that isn't necessarily 100% accurate but gives you the just of what you asking (I think)- lol!!! :confused:
  12. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    BTW, VP109 is an oxygenated fuel which will have a benefit at higher elevations.
  13. Birddog
    Mar 24, 2015
    175
    83
    178
    Cool TC, I didn't know that. How does the oxygenated fuel act with the sensors/ stock ECM? Trying to remember but I thought when we tried Q16 on our top dragster a few years ago, we needed to increase at least 4 jet sizes to avoid leaning out. I remember there was good gains with the oxygenated fuel but we couldn't get the car to run consistent on it ... The older I get, the less I remember- hahaha
  14. TNCHARGER
    Nov 19, 2015
    1,219
    478
    408
    Most pump gas is oxygenated too so no issues with sensors...
  15. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    Your car will self correct AFR from the data it is taking in from a few sources.
vp ms109
hp gain grom vp m109 fuel
is running vp109 race gas
ms109 fuel to clean
ms109 power gains
ms109 vp
vp c16 drain after each use
vp ms109
