radiator clamps
Discussion in 'General Automotive Discussion' started by 392, Apr 3, 2016.
  1. 392
    392 Silver Member
    Nov 6, 2015
    575
    84
    arizona
    I have a 2016 challenger hellcat, was looking around under the hood & noticed I have a standard squeeze clamp & a screw clamp on my upper rad hose....bottom one only has a squeeze clamp....& my rad DOES have the flared ends.....anyone else have 2 clamps....?
  2. Jungle Cat
    Jungle Cat Gold Member
    Feb 24, 2016
    1,111
    264
    258
    Yes, this was a fix for a common leak there after a certain date. I believe all 2016 should have two. Not sure what build date it started with.
  3. 392
    392 Silver Member
    Nov 6, 2015
    575
    84
    arizona
    at least they were looking out.....
  4. BIG DAWG
    BIG DAWG Hellcat, 1st Florida Cavalry Hellcat Car Club Gold Supporting Member HCC Charter Member HCC National Exec. Director
    May 4, 2015
    1,960
    1,635
    798
    Florida Panhandle
    It all started with radiator issues in the 2015s, that eventually saw, after adding a second clamp, FCA directing replacement radiators being installed in the Challengers. There was a small gauge used to test crimping on the radiator itself and it was pass/fail, with or without prior indications...anyway the double clamp is a legacy.
  5. cat8you
    cat8you Silver Member
    Jul 12, 2015
    233
    47
    michigan
    2016 charger hc 1 clamp upper hose
  6. goingsolo2
    Oct 29, 2014
    1,539
    628
    Long Island, NY
    The upper hose has 1 squeeze clamp...the recall added a second clamp on the lower part of the hose. I had a second clamp added to the top as well, while I was there. The upper hose on mine was halfway off when I took delivery of the car...glad I caught that early...that would be one smelly inconvenient mess.
