Radio Pairing Blue tooth issue.. Need help
Discussion in 'SRT Hellcat General Discussions' started by Kevin M, Mar 11, 2015.
  1. Kevin M
    Kevin M Silver Member
    Sep 18, 2014
    327
    123
    Detroit, Mich
    Does the car have to be running?? I can't get my system to pair with my iPhone 6... I've did a factory reset on my phone and everything and it still will not pick up my HK system.
    Going to try another iPhone to see if that works, if not then it sounds like I have a Blue Tooth issue with my radio. Any help would be appreciated.
  2. fnkychkn
    Jan 24, 2015
    1,499
    606
    greasy cardboard box
    does not have to be running. ignition on, engine off should work fine.
    from online database:
  3. dodgeboy
    dodgeboy Silver Member
    Dec 31, 2014
    344
    113
    Funky's right. I paired my phone in either ACC or ON (not RUN) position, and had no issues. In fact, it's probably the easiest pairing process I've had with a vehicle. Chrysler (or whomever designed this radio) really did a great job.
  4. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Yeah I hate to say it but even after a factory reset if it does not show up on your phone then maybe the Bluetooth module is missing or not working from your console radio navigation assuming your iPhone 6 pairs to other blue tooth devices correctly. i paired up my iPhone 6 plus just fine and it was like within 1 minute.
  5. Kevin M
    Sep 18, 2014
    327
    123
    Detroit, Mich
    Thanks.. I actually found out that the vehicle either has to be running or the ignition all the way on (not just in accessory mode) and that will do it.. Your right, took about one minute.
  6. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Ah ok man I'm so glad that's an easy fix. Forgot to mention I always have the car turned on when I sync.
pairing iphone to hellcat
