Ran into a problem installing new rear (upper front position) control arm
Discussion in 'Dodge Challenger SRT Hellcat' started by WNY Cat, Apr 15, 2016.
  1. WNY Cat
    Nov 16, 2014
    595
    387
    513
    I bought new rear control arms from Spohn Performance and I thought I would install them today. I started with the hardest bolt to access and I ran into a problem right from the start. After loosening the bolt and removing the nut, there is no way to remove the bolt because it hits the body of the car. It looks like the design would work if the bolt was installed from the other direction.
    The only way I can see this being assembled was to put the control arm on and then lower the whole body on to the frame. Maybe somebody on the assembly line installed it in the wrong direction? I just re-torqued it for now.
    Does anybody know the answer to this puzzle?
    Brampton Builder DGatzby
    Thanks,
    John
  2. Ray Hunsaker
    Jan 26, 2015
    624
    202
    wow that's weird. good luck
  3. PlumCrazyHellCat
    PlumCrazyHellCat Silver Member
    Feb 14, 2016
    503
    118
    Ft. Lauderdale, Florida
    Eventually the bolt head would have to be cut off to replace control arm bushings when they wear out. A small angle grinder with a cutting wheel would be another option too.
  4. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,803
    971
    Suwanee, Georgia
    Did you look at speedlogix instruction. I understand you bought from different place but their instructions are very good. I just changed rear trailing arm and took 10 mins after I read their instruction
  5. WNY Cat
    Nov 16, 2014
    595
    387
    513
    This is not the tension (trailing) arm. There are three arms, one underneath the axle and two on top. This is on top towards the front of the wheel well.
  6. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,803
    971
    Suwanee, Georgia
    I know.. What I meant to say that ... Speedlogix has instruction for these arms..
    Look at this document and see if it helps
    http://www.speedlogix.net/instructions/razorsedge/SX-LXLC-ACA.pdf
  7. WNY Cat
    Nov 16, 2014
    595
    387
    513
    sgoyal Thanks for the info.
    Here are the directions from Razors Edge.
    Use a Sawzall to cut enough of the body away to access the bolt head. Then saw the bolt head off. Really? I'm gonna think about this one before I start sawing the body.
  8. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,515
    488
    408
    The Boonies
    it sounds like the cutting was just to allow you to get on the head of the bolt to loosen it. just cut the head off now that you have it loose
  9. WNY Cat
    Nov 16, 2014
    595
    387
    513
    I tightened back up right away. I moved on to another project for today.:)
  10. DGatzby
    Jan 16, 2015
    3,724
    1,990
    748
    Twin Cities, MN
    John, you show the black arm, and that is the front upper. I can't take a wheel off now to help, but shot a picture. Also noticed both the front and the back have the nuts basically facing each other, or in other words the front has its nut towards the back and the back towards the front. I also shot this picture of the front upper, but it is not tracking with your shot. Is that the back?
    The silver connector is the back upper, right?
    So I will tell you guys, after that install your wheel hop is cured! Also expect some clicking noise from the Delrin bushings, especially low speed, uneven roads. Seems to be no problem at higher speed and smooth roads. But, it will be a spinning machine! Either it is worse for traction now, or these new NT05's really, really suck compared to PZero. It was 78 here today and they spun as bad as 48 degrees, no difference.
  11. WNY Cat
    Nov 16, 2014
    595
    387
    513
    My photos were taken on the passenger side if that helps. It's the short bar where it attaches to the chassis. Not the spindle end.
  12. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,694
    760
    633
    greasy cardboard box
    assuming you're trying to replace the tension link (#6 in the diagram).
    [​IMG]
    if so, you'll need to remove the cross member bolts on the repair side to lower that side of the cross member. this should give you room to remove the front tension link bolt.
  13. FireLane
    Jul 23, 2015
    403
    122
    Palm Beach County, FL
    The only way to change out the rear front upper control arm is to drop the rear subframe. The "Band-Aid" fix is to cut the head off of the bolt and use a new bolt going In from the other side. If you drop the rear subframe to do it you will need to do an alignment after.
  14. fnkychkn
    Jan 24, 2015
    1,694
    760
    633
    not if you only drop one side without loosening the other side.
  15. WNY Cat
    Nov 16, 2014
    595
    387
    513
    Yes. #6. Drop the sub-frame? I'm doing this with the car on 4 jack stands and one hydraulic jack to support the side that I am working on. Since I couldn't get the bolt out, I just tightened the 2 bolts back to 67ftlbs and 72ftlbs as stated in the Spohn assembly instructions. I haven't tried anything else yet.
2015 challenger hellcat rear control arm bolt captured
adjustable spohn control arms lose nuts
hellcat challenger spohn
hellcat control arms
razors edge challenger control arms
spohn performance challenger rear control arms
