Rear Axle Seal Leaking
Discussion in 'SRT Hellcat General Discussions' started by IA_Cat, Apr 21, 2015.
  1. IA_Cat
    IA_Cat Silver Member
    Oct 22, 2014
    150
    49
    Today, while swapping wheels and tires, I discovered that I have a seal leaking where the axle goes into the differential on the passenger side. I only have 211 miles on the car and have babied it. I really don't want to leave my car and keys with someone else. Is this the style where they'll have to pull everything out of the diff to install a new seal?
  2. B5 Blue
    1,745
  3. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    595
    281
    Houston, TX
    "The rear axle has been refined for the entire Challenger line, including a 230 mm ring gear on all V8-equipped cars. The ring gear is welded to the carrier for improved strength and efficiency. Currently, only seals, mounting bushings, and fluid can be replaced (Figure 27). Defective gears and bearings require replacing the entire axle assembly. "
  4. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    595
    281
    Houston, TX
    That might give a clue. That's the only mention of it that I remember coming across in my reading.
  5. IA_Cat
    Oct 22, 2014
    150
    49
    I got it fixed today. The dealer had the seal in stock and it only took them a couple hours. I asked to see the original seal and it looked perfect to me. The tech wasn't sure why it was leaking. Hopefully it is permanently resolved.
  6. Jim M
    Jim M SRT Hellcat Supporter Gold Supporting Member
    Jan 12, 2015
    620
    217
    Oviedo, FL
    Keep an eye on it for further leakage. The original seal may not have been properly installed at the factory. Or there could be a bad spot on the axle where the seal is.
  7. Jared SRT Cat
    Jared SRT Cat Silver Member
    Jul 16, 2015
    253
    88
    indy
    Here is my rear seal leak.. Dealer is replacing the entire rear axle, boots, etc.... Luck me
    • Useful Useful x 2
  8. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    70.196059, -148.559760
    Don't sweat it. That is minor stuff in the big picture and it sounds like your dealer is working hard to make it right. You will be back making boost in no time! Let us know how it goes.
  9. Jared SRT Cat
    Jul 16, 2015
    253
    88
    indy
    Yeah im not too upset.. Hard not to be a little bit dissapointed though.. I guess thats what warranties are for though!
  10. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    I hear you. It always stinks when it is your car but like I said, could be way worse.
    Warranties are good!
  11. Jared SRT Cat
    Jul 16, 2015
    253
    88
    indy
    Definetely! Im really hoping after this fix it eliminates all that noise in the rear end i have been hearing.. I will be paying much more attention to the car now..
  12. Paladin06
    Sep 3, 2014
    4,915
    2,036
    818
    San Tan Valley, AZ
    Man that really sucks. Just had mine in for 2nd oil change and I went through the undercarriage with a flash light and all was good.
  13. Jared SRT Cat
    Jul 16, 2015
    253
    88
    indy
    Good to hear!! Mines since been fixed and all is well
  14. Eurohellcatman
    Eurohellcatman Rookie
    Dec 22, 2015
    22
    7
    Hi all.
    This could be a good conversation to jump into as I'm new to the club and I've just picked up my new hellcat and within the first 1000 miles and I noticed something like water and oil and "dry" oily residue on the garage floor. (Photo below).
    In terms of its position on the garage floor, it's the center of the vehicle - and I've also heard a metallic sound at low revs easy acceleration, so gentle in fact that you don't hear the supercharger wine so this is pure car sound. Kind of like the metallic sound a highly tuned m3 would make...it goes away if push the car harder from low revs.
    My question is; has anyone got the similar sound and has anyone seen any oil on the floor??. My dealer says it could be nothing after the very long drive I did ... 600 miles ... But the sound is keeping me awake at night LOL.
    Thanks if anyone's got some thoughts
  15. fnkychkn
    Jan 24, 2015
    1,603
    695
    greasy cardboard box
    Dunno about the sound but that picture is exhaust soot and nothing to worry about.
2015 challenger leeking rear axels
challenger axle leak
challenger hellcat differential
challernger srt rear diff leak
hellcat challenger rear axel assembly
hellcat failed rear side axle
rear axle seal
what does the hellcat dodge have for a rear axle
