Rear end noise
Discussion in 'Dodge Challenger SRT Hellcat' started by Blackcatinoregon, Jun 16, 2016.
  1. Blackcatinoregon
    Blackcatinoregon Rookie
    Jun 8, 2016
    11
    1
    When making a slow right or left hand turn into a parking space I'm hearing a groan from the rear end. Dealer changed fluid and found no problem. Any thoughts on this
  2. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,603
    451
    368
    Henderson, NV
    Lots of guys have this. It's the CF clutches rubbing together. Normal. You can try adding friction modifier to quiet it but then you take the chance of hurting LSD operation. It's not hurting anything. I've learned to ignore it.
  3. Blackcatinoregon
    Jun 8, 2016
    11
    1
    Great, thank you, I will ignore it too.
  4. Peter Gozinya
    Peter Gozinya Silver Member
    Mar 20, 2015
    380
    163
    I have it too. I think it is just a common thing. I had them check it, change fluid, do alot of slow turns in the parking lot. I have it noted in the system that they hear the noise as well. They are checking with SRT. I am kind of "happy" that it is happening to others therefore it may be just the way it is.
  5. rayzazoo
    Nov 8, 2014
    3,468
    1,283
    668
    All they need to do is change with new fluid and add the Mopar friction modifier.
    Rear end groaning noise
dodge challenger rear end noise
hellcat forums rear end whine
