Rear Taillight Adjustments
Discussion in 'Dodge Challenger SRT Hellcat' started by AZ HELLCAT, Feb 13, 2015.
  1. AZ HELLCAT
    AZ HELLCAT Gold Member
    Dec 9, 2014
    516
    334
    Does any one know if the rear tail lights can be adjusted? My far right rear is about a 1/4" lower than the left right rear that is attached to the trunk. The complete left side tails are dead nuts on.. It's driving me crazy..
  2. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    There's a thread on here about this. Search for it. Your dealer can do it for you also.
  3. AZ HELLCAT
    Dec 9, 2014
    516
    334
    Thx. Any idea where? My dealer is telling me it can't be done.... Wth...
  4. AZ HELLCAT
    Dec 9, 2014
    516
    334
    Anyone?
    Bueller, bueller, bueller.....
    I can't be the only one....
  5. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    310
    Oklahoma
    I can't find it, I've been searching for 20 minutes. If it's anything like my '06 SRT8 Charger or most late model cars, you just have to pull the trunk lining material away from the back, usually its held on with plastic screws or push pins. It's kind of like a carpet type housing covering the very back (rear-most) wall of the trunk. If you can get that pulled back/away, you will see the back side of the tail lights and be able to loosen the screws that hold them in slightly, adjust light housing to preference, then tighten the screws back up. Reverse the rest of the procedure to reassembly.
    I know if it does it more than once to me I'm going to put some blue loctite on the tail light housing screws.
  6. rayzazoo
    Nov 8, 2014
    3,466
    1,280
    668
    You can also adjust the black trunk bumpstops to adjust the middle. As mentioned by RadCat, the taillight assembly can be adjusted by pulling back the trunk lining material behind the light.
  7. AZ HELLCAT
    Dec 9, 2014
    516
    334
    Nice goes into dealer Friday for a bad scratched up door panel that the car showed up with. 1700 bones I guess. Ehhhhh. Then the rear bumper lower balance was scratched pretty bad they have to replace also. Going to make sure they do the lights. Keep u in loop. Thx guys!!
  8. fantastical
    fantastical Hellcat Member
    Nov 6, 2015
    61
    Jacksonville, FL
    image.jpeg So I am rehashing this because I noticed the same issue a few days after I bought my 392. The first "fix" was adjusting trunk lid. No help, but the lid lined up better. Next was swapping out the light. No go. So I have set up another appointment with another shop. A tech DID notice something interesting while I was getting their opinion. My lid could be pushed down almost an inch. Going to a car on the lot with the lights lined up properly showed no downward movement with the trunk lid. So, they concluded that the trunk latch MAY need adjusting, or may be defective. I will find out tomorrow.
    The main reason I am rehashing this is because I have notice quite a few SRT's with this right rear light issue. Not one or two, but more than a dozen in my area.
    I will keep you all posted. If anyone has fixed this issue already give me your input.
  9. Bandit
    Bandit Gold Member
    Jun 20, 2015
    975
    307
    lol
    Congrats, you've noticed something that has plagued every run of Challenger (all trim levels from SXT to Hellcat) since they were released in 2008.
  10. fantastical
    Nov 6, 2015
    61
    Jacksonville, FL
    Thanks...
  11. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,622
    906
    Virginia
    My 2010 Challengers R/T was a real pain to get lined up and keep that way. and yes it was on the right side...
    Good luck!
  12. AZ HELLCAT
    Dec 9, 2014
    516
    334
    My dealer fixed no prob
  13. fantastical
    Nov 6, 2015
    61
    Jacksonville, FL
    Do you recall what the fix for it was?
  14. AZ HELLCAT
    Dec 9, 2014
    516
    334
    I didn't ask but they said it was easy. I just told them get her done!
  15. Peter Gozinya
    Peter Gozinya Silver Member
    Mar 20, 2015
    379
    163
    I have the same issue. It's the right side. It is down 1/8 to a 1/4 inch. I am sure they can adjust and will have the dealer do it at next oil change. No glad to see it is an issue with most but relieved to say it can be fixed.
hallcat challenger rear lights
hellcat black tail lights
hellcat challenger rear lights
hellcat taillight
