Rear tire wear
Discussion in 'SRT Hellcat General Discussions' started by Catscratch Fever, Feb 28, 2016.
  1. Catscratch Fever
    Catscratch Fever Silver Member
    Jul 10, 2015
    603
    112
    Ive got 700 miles on my challenger Hellcat. I noticed that the rear tires aren't wearing the same. The driver side rear tire doesn't wear to the outside like the passenger rear tire does. Any help? Difference is about and inch
  2. Lord Hellcat
    Jan 6, 2015
    1,609
    725
    UK
    It sounds like the rear camber is off. I don't know if it adjustable on the Challenger
  3. Catscratch Fever
    Jul 10, 2015
    603
    112
    Top photo is passenger rear, bottom photo is driver rear. Driver rear tire the wear doesn't extend as far as passenger rear tire. Any suggestions.
  4. Catscratch Fever
    Jul 10, 2015
    603
    112
    So is the rear camber adjustable?
  5. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,170
    314
    Newport, MI
    Maybe you're just taking more hard left turns lol. I'd be curious how the inside is wearing on each side as well
  6. kenhebe
    kenhebe Silver Member
    Jun 24, 2015
    518
    120
    Tire pressures can cause this as well.
  7. Hellcatmichael
    Hellcatmichael SRT Hellcat Supporter Gold Supporting Member
    Oct 20, 2015
    981
    291
    173
    I don't know much about what is or is not normal tire wear on a new car with 700 miles but I only have 200 miles and they look like they are doing the same as yours. I have no pulling or abnormal vibrations so I'm just going let it go as normal and see what they look like in about 5000 milles or so before I get concerned.
  8. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,011
    484
    403
    Westchester
    I've got vibrations above 80 and rotating and balancing didn't fix it. I read in one thread that these tires develop flat spots really easily which means these tires show wear easily. Think about your trips when you drive, Are they mainly left turns? What about tire pressure is it within 1-2psi of each other? Did you choose secret open diff option and have been doing 1 wheel burnouts?
  9. Catscratch Fever
    Jul 10, 2015
    603
    112
    Tire pressure cold set at 32 psi all around.
  10. Catscratch Fever
    Jul 10, 2015
    603
    112
    No hard driving. I don't drive it in track mode. Whatever is default is what I go with. No vibrations.
  11. Chippy
    Chippy Silver Member
    Nov 27, 2014
    656
    140
    Alberta
    Somethings not right. I was just looking at last summers NT05's and will be needing new ones by half through this summer, but, they are exactly the same wear pattern almost bald steam rollers.
  12. Catscratch Fever
    Jul 10, 2015
    603
    112
    I've got plenty of tread for now, I just don't know if the rear camber can be adjusted? If not how do you fix rear camber problems, by adjusting the front?
    Can someone post the alignment specs for the 2015 Challenger Hellcat. Where do you think is the best place to get the car 4 wheel aligned, dealer? If so, are these cars covered for alignment under warranty with only 700 miles?
  13. Challengerta
    Challengerta Rookie
    Jan 16, 2016
    10
    2
    Right rear tire always wears a little faster than left as this is the first wheel to spin. Has to do with engine torquing and rear gear setup. Even with a posi, pass side spins more.
  14. DGatzby
    Jan 16, 2015
    3,395
    1,778
    598
    Twin Cities, MN
    No, that is not right; have your alignment checked that one side is dragging itself around.
  15. JerseyCat
    JerseyCat Hellcat Member
    Sep 30, 2015
    41
    26
    18
    I agree. Both lines on my rear tires wore off exactly the same. I'd get it checked.
dodge challenger rear tire wear
dodge challenger tire wear
