Removing the PCM
Discussion in 'SRT Hellcat Electronics' started by rodgdodg, Sep 25, 2015.
  1. rodgdodg
    rodgdodg Rookie
    May 27, 2015
    6
    1
    Philadelphia, Pennsylvania
    I am trying to remove the PCM from my challenger hellcat to send it off to diablosport so that it can be unlocked, but I'm having a lot of trouble getting the PCM out of the car. I can't get the plugs out. Seems to me that there just isn't enough space to separate plug from PCM. Anybody have any tips for getting it out? It would be extremely helpful. Thanks in advance.
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,709
    2,039
    Yes,, this is a good question,, plus where is the pcm/ecm
  3. Bucks666
    Bucks666 Silver Member
    Apr 21, 2015
    183
    63
    Central Ohio
    Should be under the passenger side wiper area , small black piece that pops out . Had to disconnect down in the hole its in , as the wires coming in didn't give you enough play to pull out the pcm before disconnecting .
  4. SRTFighter
    SRTFighter Silver Member
    Mar 21, 2015
    755
    165
    Houston, TX
    I am looking into doing this soon. Could anyone post some pictures or a detailed how to?
  5. spenosk8er
    spenosk8er Silver Member
    Aug 20, 2015
    117
    59
    198
    Los Angeles
    As you are looking at the engine bay it is in the very back left... correct me if I'm wrong but it's under the "vented" part of the black plastic cover that pops out with the push of a clip. Once that is off, the PCM disconnects with one of those red tabbed, annoying clips I believe
  6. spenosk8er
    Aug 20, 2015
    117
    59
    198
    Los Angeles
  7. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    It's a pain in the but on the challenger .a lot of wiggling around and I think I remember removing some of the push pins to be able to move the plastic
  8. SRTFighter
    Mar 21, 2015
    755
    165
    Houston, TX
    I found a video for a charger on Diablosport's website. Looks simple enough.
  9. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,908
    5,473
    963
    Once that pcm is accessed it will leave a footprint of data that can't be erased. Be careful if your in warranty
  10. SRTFighter
    Mar 21, 2015
    755
    165
    Houston, TX
  11. SRTFighter
    Mar 21, 2015
    755
    165
    Houston, TX
    The way I see it is if you care about a warranty then you should not be modifying anything on your car. I know enough about cars that I personally could care less about warranties.
  12. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,908
    5,473
    963
    Great point. Your knowledge will make your car and value to you better. Have fun and take care of that rocket ship hellcat. Be safe.
    Have a good weekend
  13. RussLansky
    RussLansky SRT Hellcat Supporter Gold Supporting Member
    Apr 5, 2016
    32
    47
    18
    If you change the pcm and then later change back to the factory pcm will the mileage be the traceable way for the dealer to tell the pcm was changed and then changed back.
  14. rayzazoo
    Nov 8, 2014
    3,970
    1,619
    818
    I see warranties as simply a "dealership pays to maintain" or "you pay to play".
    With the Hellcat, I see the modifications as: driver skill/knowledge, proper tires, proper fluid maintenance, brake pad maintenance, engine belts, and several other things warranty doesn't cover to begin with.
    Far too often, we get bit by the mod bug to chase HP, but we forget to invest in the knowledge behind the wheel and the things that keep the car great in the first place.
  15. Link
    Link Silver Member
    Jan 27, 2015
    922
    210
    to get more room just loosen the cross brace and you will be able to slide the whole thing up. Be careful, there is a locking tab in the center of the lever that you need to push to release the latch that holds the cable on.
    Mine didn't have the slack on the cable the 300 did, was a pain.
2015 challenger pcm removal
2015 hellcat pcm removel
2016 hellcat pcm
challenger remove pcm cover
getting data from hellcat pcm
hellcat pcm removal
hellcatt pcm location
how to remove pcm from challenger 2016
