Request for Picture of Auto Transmission Neutral Override
Discussion in 'Dodge Challenger SRT Hellcat' started by JonWrong, May 15, 2015.
  1. JonWrong
    JonWrong Silver Member
    Feb 3, 2015
    358
    51
    Orlando, FL
    I had my HC Charger towed yesterday after a coolant leak. It turned out to be a bad radiator drain cap gasket. To get the car into neutral while not running, you remove the plastic trey right next to the shifter, a plastic cap, and then pull a lever with a red strap. Video showing someone else doing that is below.
    On my car that was a metal tab on the right side of the lever (in the center when the lever is in the down position) that prevented the lever from going back down and back into park. When I tried to bend it out of the way (b/c it had to be moved) it broke off. This is a very thing metal tab about the size of a dime or nickel. I am wondering if is in place on other cars and what it looks like before someone messes with putting the car into neutral. I was hoping some good Samaritan would look a take a pic. The neutral lever is spring loaded and locks in the up position, so I do not think the clip is needed.
    Thanks in advance.
  2. MrBigKid
    MrBigKid BANNED
    Nov 29, 2014
    1,341
    409
    278
    Columbia, SC
    Hope these help. That tab just looks like a safety clip to make it snap so it's not pulled without you knowing it I guess. I don't see how it could hurt to have it off. I did open it up and pull the lever and was able to snap it back in place but it takes just enough effort so that it can't be done accidentally
    • Winner Winner x 2
  3. B5 Blue
    1,745
    Real nice pics of this
  4. JonWrong
    Feb 3, 2015
    358
    51
    Orlando, FL
    Pics are awesome! I really appreciate it! The clip on mine won't be missed.
  5. Hb hellcat
    Hb hellcat Black Betty...BamAlam!!!
    Feb 14, 2015
    557
    176
    Sunny Southern California
    Great pix., now I see that some others are as picky as I am.
    Love the way the strap is cleaned, smoothed and properly placed. A good wipe down on the leftover dirt is always appreciated as well!
    That's exactly how I will be doing it when the time comes.
    Congrats on a job extremely well done!
  6. HC Steve
    HC Steve Senior Hellcat Member
    Mar 23, 2015
    56
    43
    Central Coast California
    Because I had seen this awhile back, I was able to assist a hellcat charger who ran out of gas on a cruise yesterday and we needed to push his car a bit to get it off the side of the road. The "tab" actually broke off but I too see this as no big deal. It did not slide enough rearward to clear the mechanism being pulled vertical so when I tried to bend it with a screw driver it broke off. Thanks for posting the photos! They definitely helped!!
2014 dodge charger neutral position
2015 dodge charger neutral override
hellcat automatic transmission cooler
hellcat neutral override
how to put a charger neutral override back in place
