Second oil analysis
Discussion in 'SRT Hellcat Maintenance' started by SRT_HC_707, Jun 7, 2015.
  1. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    70.196059, -148.559760
    For anyone in interested. My first and see second oil analysis side-by-side
    • Useful Useful x 6
  2. TallCool1
    2,433
    817
    Pacific NW
    How long due you plan to leave oil in? I'll be interested in fuel dilution at 2K and 3K. And oil at that time maybe run tbn and tan at the end of your use.
    Is this the same oil tested twice but at different mileage?
  3. Lord Hellcat
    Jan 6, 2015
    1,594
    712
    UK
    Good job SRT
  4. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    First oil CHANGE at 500 (analysis in file posted above)
    Second oil CHANGE at 1537 (1037 miles on oil with analysis posted above)
    Next change will probably be when the odo hits 3K. I'm extended each change out a bit until I get to my 'normal' oil change interval which is yet to be decided for me. Somewhere at 5K or less most likely. I'll run a TBN when I get to a change with more miles on it. TBN at 1037 miles isn't going to be very interesting.
  5. Deputydog
    Deputydog Gold Member
    Nov 2, 2014
    1,002
    261
    Spokane, Washington
    Looks pretty darn good to me!
    At what point do you capture your sample of oil to send in? I would assume as soon as the plug comes out?
  6. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    I usually let the oil drain for about 20 seconds or so and then grab the sample by putting the sample bottle into the stream.
    They recommend letting some oil drain before grabbing the sample.
  7. FatCat
    FatCat VIP Hellcat Member
    Apr 1, 2015
    111
    41
    98
    SouthEast
    Got my first change at the dealership - 700 miles.
    I retained the original OEM filter. What's the best way to take it apart or where should it be hack sawed?
  8. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    Cut it at the base right above the ridge. I cut both of mine I'll grab a pic tomorrow if I think of it. You basically want to cut all the way around like you are cutting a pipe but don't cut through your you will go through the filter element.
    Hacksaw, sawzall, grinder, whatever you have is fine.
  9. TallCool1
    2,433
    817
    Pacific NW
  10. Trucker Bob
    Trucker Bob Silver Member
    Feb 21, 2015
    371
    91
    Northern IL
    I should be changing my Amsoil with analysis in a few weeks. I did the first change at 780.. I just took Her on a 1100 mile trip. I want to get some local miles before I change the Amsoil out. I will try to post the results. Not tech savvy.o_Oo_O
  11. Next Phase
    Next Phase Silver Member
    Oct 22, 2014
    908
    301
    173
    Thanks for posting! I'm doing my first oil change and sending to Blackstone as well.
    Interested in hearing the optimal oil change interval. I'll most likely shoot for 4k to 5k miles
  12. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    Regular analysis will help you determine what the optimal interval is for your engine, the oil you use, how you drive etc... Eventually I'll probably be at around the 4 or 5K range myself. I don't have any desire to go longer.
    Please post up your results when you get them back. I'd love to compare my engine to others here.
  13. Next Phase
    Oct 22, 2014
    908
    301
    173
    Sure thing!
    I'm positive my numbers will be elevated as I didn't do the 500 mile break in and I am in boost every chance I get....lol
  14. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
    Thanks SRT_HC_707 I wish my iPhone could pull the PDF up :(
  15. Trucker Bob
    Feb 21, 2015
    371
    91
    Northern IL
    I could not open on my Mac book:( Like I said not tech savvy o_O
