Sell me your car!
Discussion in 'SRT Hellcat Performance' started by BooSSted, May 28, 2016.
  1. BooSSted
    BooSSted Rookie
    May 27, 2016
    5
    0
    1
    Not literally :)
    I'm an avid GM guy, love the current pony cars. Current car is a 2011 SS making 640whp with your bolt ons and blower. I'm in the market for a new car this summer and I'm not a big fan of the ZL1 styling even with the Z06 platform. So I've turned to Mopar for answers!
    Love the platform and styling so I just really need to get down to the nitty gritty of reasonable limitations of the car/platform, and the actual support number of reputable resources. (Tuners, Aftermarket Mods)...
    Goals:
    16 HC - A8
    1/4 - Mid 10's minimum @ 138+ mph minimum
    Power - 780whp +
    Budget - 30k in initial mods
    After reading through 2 pages of builds and 15 pages of performance pages I've got a lot of information. Most of it was scattered so if I happen to repeat something please save the "go search" comments.
    Must Do's ... DR's, 309 Gears, DSS Driveshaft.
    My build will have to be on pump 93 gas as there isn't E85 options avaliable in my area and race fuel isn't realistic at this time as my car will see the track 4-5 times a year.
    I've only seen one or two builds mention running meth, why is that?
    If not for octane at least for cooling purposes.
    I also haven't seen the mention of any cam builds? I don't have to dive into the benefits of a cam but this is surprising to me.
    With the maximum stock boost of 15 psi, with bolt ons and a tune on 93 through the A8, what numbers can be expected 'ballpark' ? Is there a fast list some where on the site that list modifications ?
    The mention of small NOS shots are often passed around, but what is defined as a small shot of nitrous?
    Tq management through the A8... This is a problem for all brands of cars now it seems. 900whp looks to be the barrier; a barrier I'd be just happy to stop at haha... Are these high HP builds all supporting nitrous?
    What are the power limitations for A8 transmission? Any issues noted from the higher HP guys?
    Outside of HHP what other shops are a good resource for the Mopar community?
    And a list of the top vendors and or go to aftermarket sites? I know some are better than others I'll take the private messages to not upset the powers to be on the site.
    • Useful Useful x 2
  2. jvm728
    jvm728 SRT Hellcat Supporter Gold Supporting Member
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    You could make me an offer on mine. It has everything you want to do, other than 3.09 rear. 600 miles on it, PCP w/ black hood 2016 A8
  3. Markp
    Markp Gold Member Hellcat Car Club Gold Supporting Member HCC Club Member
    Aug 5, 2015
    1,830
    734
    Ontario, Canada
    10.5s should be pretty easy drag radials, 3.09, pulley tune should get you there.
  4. blaze
    blaze ☆★✪ The Watcher ✪★☆ Hellcat Car Club Gold Supporting Member
    Dec 28, 2015
    2,024
    959
    498
    26.7100° N, 80.0500° W
    i copied this from someone back in February:
    1. Dodge hellcat goes 10s on radials and weather conditions ...
    2.drive shaft one piece is a must...
    3...stock fuel pump has built bap to feed ihi
    And half inch fuel inlet on rail
    4. Stock all seasons get flat spots and cause vibrations
    5. The m6 cars always Dyno little higher numbers
    6. The cranks are not pinned
    7. The front brakes make sounds at low speed like bad cv joint symptoms
    8. Car does not go in neutral by using shifter, Tranny lock had to be pulled located on side of shift wit red ribbon
    9. best street able pulley upgrade is 2.85
    10. 3.09 rear is direct swap and 1-2 tenths gain on 1320 times
    11. Fans don't go on until about 213 degrees
    12. Stock air box just as good as aftermarket no gains to be made
    13. Nitrous and hellcat just works
    14. Stock spark plugs is iruim gapped 0.31 -0.34 from factory
    15. Smaller rear rims requires end links swap
    16.a few body panels not perfect
    17. For e85 conversion only injectors need to be swapped and re tuned
    18. Ati lower pulley adds 2-3 lbs
    2.85 is 4 lbs
    19. Pump gas your limit on safe power is about 800
    20. The block and heads are fantastically designed
    21.. The factory tune is so on point
    22. The wideband makes small corrections to make the car run efficient
    23. Colder it gets faster the cat becomes
    24. Headers or exhaust isnt best mod power to dollar
    25. How much horsepower does it take to get 9.99 or faster depending weather (8%%- and up
    • Winner Winner x 3
  5. BooSSted
    BooSSted Rookie
    May 27, 2016
    5
    0
    1
    Great info, thanks for the replies. When the boost is maxed (15#), are any shops adding meth? @HHP?
  6. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,817
    1,301
    933
    Kenosha, Wisconsin
    Boost isn't maxed at 15#...
  7. Link
    Link Silver Member
    Jan 27, 2015
    843
    176
    think safe limit someone said is 18psi, need tune to achieve. it is just a matter of pulley size and tune.
  8. LukeFortney
    LukeFortney Rookie
    May 7, 2016
    28
    10
    Sioux Falls, SD
    Dude...why would you sell?!
  9. BooSSted
    BooSSted Rookie
    May 27, 2016
    5
    0
    1
    That's why I pose the questions haha.. Reading through I seen several members state 15# is the max recommended on pump 93.
    Boost isn't the end all... That's also why I asked about cams, as they usually drop boost levels. So if you do have the fuel you have more wiggle room before max spinning the blower.
  10. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,041
    2,904
    818
    Great post. I would never sell my cat for all
    Of king Solomons silver.
    The peace and tranquility that comes with it is priceless
    Even global gym and white goodman. Lol
    • Funny Funny x 2
  11. jvm728
    Mar 14, 2016
    200
    55
    28
    McKinney TX
    I love the car but don't get to drive it hardly ever. Married, work from the house, 2 kids and 1 on the way, so I'm hardly ever out driving alone
  12. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    6,041
    2,904
    818
    The peace and tranquility that comes with our cars is priceless. However I understand if some one had for sell it for reasons that's someone may not get or even understand that too
  13. Beast600rawbench
    Beast600rawbench Rookie
    Jun 25, 2016
    16
    2016 a8 challenger 4k miles I'll sell you :)
sell me your hellcat
