Shift rpm ?
Discussion in 'SRT Hellcat General Discussions' started by GrndFnk, Feb 4, 2016.
  1. GrndFnk
    GrndFnk Silver Member
    Jan 13, 2016
    56
    178
    Stock. A8. Wish these had a playback.
    Questions :
    \Where does it typically shift in full auto ?
    What is optimum using paddles ?
    Where is the rev limiter set ?
    Thanks.
    EDIT: A side note...my '16 didn't come with a double clamp on the top radiator connection....what was the deal with the '15's out of curiosity...didn't the radiator fitting have a shoulder on it ?
  2. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,472
    758
    Virginia
    shift points vary with mode...street, sport, track. Wild to mild and back again. ECO mode will soften it out even more.
    Track is aggressive with extremely crisp shifts keeping rpms up and will also downshift fairly aggressively. Sport backs off from that a bit. Street is your easy mode.
    NOTE: All modes will have aggressive downshifts under 3/4 to WOT even ECO
    You can suppliment auto with paddles or use manual mode to get full control
    Check your Tach...redline is redlined but traction control might also weigh in if you're having too much fun.
  3. GrndFnk
    Jan 13, 2016
    56
    178
    I should re-phrase my question to: what is the "optimum" shift rpm on a stocker for best quarter mile performance ?
    Looks like I will start with using track mode shift/ sport TC / street suspension....is the plan with a driveshaft and drag radials using the monkey see monkey do formula for go fast.
    Paddle shift if need be depending on what will give the best results. Seems the HP curve keeps climbing past 6K according to a few dyno curves I have looked at. Even tho a dyno is just a relative thing that part of it seems to be consistent from dyno to dyno.
    Thanks Toolman
  4. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,101
    732
    i used Auto stick on my A5 2011 SRT.....ive never used the paddles or autostick once on the HC....i think in Sport mode the car does it all for you...i dont think you can improve on the stock shift points....Dodge actually did this car right.....their A5 really sucked w/ shifting....the A8 is flawless
  5. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,555
    438
    368
    Henderson, NV
    Rule of thumb is you want it as close to the limiter as you can without hitting it. You are correct this car is still building power well past the 6200 fuel cutoff. Most guys just put it in D, track mode and you're good to go. I wish there was an option to raise the limiter to 6500.
  6. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,442
    457
    258
    The Boonies
    optimum shift point is right before the engine cuts out!
  7. GrndFnk
    Jan 13, 2016
    56
    178
    Thanks for the replies, all good info..... On my '09 SRT there were a couple hidden screens someone found and I can't remember what they are at the moment... and I wouldn't be all that surprised if there was a hidden playback function to watch it go thru the gears so we could see the actual shift points .....You can bet if there was a warranty dispute they would come up with one...magically :(
  8. GrndFnk
    Jan 13, 2016
    56
    178
    The red line on my tach is 5750. The 2 dollar question I have is where does it actually shift in track mode/auto..It would be reasonable to assume 5750 but it is not a given, ..A user accessible playback function would be a real nice flash/update to have at some point.
  9. Racist Cat
    Racist Cat Silver Member
    Jan 28, 2016
    1,385
    494
    When I am horsing around in manual mode, I am always hitting the rev limiter.
    The engine just doesn't seem like it wants to shift yet. There's more power to be had in the higher rpm.
    When I'm racing, I usually manually shift 1-2, and maybe 2-3 depending on traction. After that it's auto mode.
  10. GrndFnk
    Jan 13, 2016
    56
    178
    [QUOTE="Racist Cat]When I am horsing around in manual mode, I am always hitting the rev limiter.
    When I'm racing, I usually manually shift 1-2, and maybe 2-3 depending on traction. After that it's auto mode.[/QUOTE]
    I want to get my ducks in a row here being this functions so much differently than my '09.
    So, correct me if i am wrong, you tend to keep the shift lever in M then after the 2-3 you bump it over to the right and let it go
    auto ?
    Another question I have is how quick do the paddles respond to a command ?
    Thanks
  11. Racist Cat
    Jan 28, 2016
    1,385
    494
    The paddle shift is completed the moment you squeeze them. Before your finger can release the paddle the next gear is engaged solid.
    Correct. I put the shifter in M, and feather out 1st, usually short shifting to 2nd, then get on the throttle real heavy, and if the ground is loose, I'll somewhat short shift 3rd, and go wot, and then reach down and bump the shifter to auto.
    I drive my car in Manual mode 99% of the time, and with traction control off.
    There is no mushiness in the Trans. Feels like a manual when shifting and decelerating. If you catch the rom right on he downshifts you can get some pretty good exhaust rumble and minor backfire.
  12. GrndFnk
    Jan 13, 2016
    56
    178
    Good info.
    I have a set of 10 x 17 Welds that I think I will put the 28.1 tall 305 Street R's on and pick up the shorter rear links from HHP.
    The goal is to be able to leave the line with the peddle to the wood.
  13. Racist Cat
    Jan 28, 2016
    1,385
    494
    You will need some other drivetrain miss to be able to do that. Too much power in 1st gear
  14. GrndFnk
    Jan 13, 2016
    56
    178
    I have an aluminum driveshaft on the list.. I like the CF but the heat down there may get near the endurance threshold in the summer months, plus I wonder about
    stones bouncing around occasionally and nicking it. Probably non-issues but you never know. I like the idea of the CF absorbing some of the shock when you launch hard.
  15. Racist Cat
    Jan 28, 2016
    1,385
    494
    I haven't tried it yet, but ice heard some people have bett er luck launching in 2nd.
2015 challenger shift rpm srt
best rpm to shift a 2016 challenger
challenger hellcat rpm
hellcat decelerating
hellcat forum best shift rpm 0-60
hellcat shift light
srt 392 a8 shift problems
srt 392 paddleshift will it downshift automatically
