Shorty Valve Stems with TPMS??
Discussion in 'SRT Hellcat Wheels and Tires' started by Driver72, Sep 26, 2015.
  1. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,225
    285
    Anybody know if they offer TPMS valve stems for our cars with shorty black tips so they don't stick out so far?
  2. Driver72
    Mar 10, 2015
    1,225
    285
    Also if no shorty valve stems are available with the TPMS system, and I still decide to go with shorty valve stems without the TPMS systems, anybody know if there is a fuse dedicated to the TPMS system that I can pull so I don't have the low tire pressure light on, on my dash all the time?
    Thanks
  3. 06SRT10NR
    06SRT10NR The K.N.O.B. Rules Hellcat Car Club HCC Charter Member
    Nov 9, 2014
    241
    86
    Team Hellcat GA
    Don't know for either question, but I have wheels being made now that'll have a bracket welded inside to hold OE-like TPMS sensors 180 deg off from custom made valve stems.
  4. Driver72
    Mar 10, 2015
    1,225
    285
    Wait what? I can't picture what you are describing.
    The wheels I ordered have valve stems that come out near the center of the wheel. Apparently this is common now, as it apparently looks better since you don't really see them. However with our huge brakes that causes a problem as they will hit the brake caliper. This is the issue I'm having with my new wheels. So I need to get shorty valve stems. I'd prefer to have TPMS sensors with them, but local tire/wheel place manager said he's never seen shorty valve stems on TPMS sensors, only normal valve stems.
    So if I need to get regular valve stems for the front wheels, I'd need to pull the low tire pressure light fuse, if they have one...or I need to return/sell the wheels/tires I got. But I've mounted and balanced the wheels and tires already, so the Tire Rack won't take them back.
  5. 06SRT10NR
    Nov 9, 2014
    241
    86
    Team Hellcat GA
    It'll be a few weeks before I have them, so I only have a verbal description, with several possibilities running around in my head. For the same reason you have, front brake caliper clearance. Dude tells me it's becoming a fairly common workaround. May not be able to get that done at Tire Rack, but maybe another shop in your area that works with custom wheels
  6. 06SRT10NR
    Nov 9, 2014
    241
    86
    Team Hellcat GA
    Looks like fuse #25 in the box in the battery compartment should be the one to pull
  7. SHAWNYMAC
    SHAWNYMAC Hellcat Member
    Jun 17, 2015
    105
    17
    18
    JUPITER FLA
    hey can you confirm this is the fuse?
    my sensors read the pressures but light is on....
  8. 06SRT10NR
    Nov 9, 2014
    241
    86
    Team Hellcat GA
    a bit too dark outside to recheck at the moment, and I'll have to unload a bunch of stuff from the trunk, but fairly sure I didn't typo the fuse #
    might it be a different fuse for a 392?
  9. SHAWNYMAC
    Jun 17, 2015
    105
    17
    18
    JUPITER FLA
    should be the same...you said in the trunk near the battery?
  10. 06SRT10NR
    Nov 9, 2014
    241
    86
    Team Hellcat GA
    yep, had to push the neg battery cable out of the way to take the cover off
    edit: just checked a recently downloaded version of the owners manual, I know it's not exactly an authoritative document, but looks like HC and 392 are supposed to be the same ... 10 amp red mini fuse, in #25, in the rear power distribution center
  11. SHAWNYMAC
    Jun 17, 2015
    105
    17
    18
    JUPITER FLA
    so light will go away but pressures will show up still?
    thanks for the help
    just got new wheels and rims and bought after market toms sensors but light just came on and pressures are registering
  12. 06SRT10NR
    Nov 9, 2014
    241
    86
    Team Hellcat GA
    only tried it once, killed the warning light, don't remember if I checked to see if pressures registered or not. it was a while ago. next time Im in the car, I'll check to see if 25 was indeed the one we pulled
  13. SHAWNYMAC
    Jun 17, 2015
    105
    17
    18
    JUPITER FLA
    Ok awesome !!!!
  14. 06SRT10NR
    Nov 9, 2014
    241
    86
    Team Hellcat GA
    have you tried disconnecting the battery to reset everything? was what finally resolved the issue for me. same basic cause, aftermarket toms. tried reprogramming them first, didn't work
  15. SHAWNYMAC
    Jun 17, 2015
    105
    17
    18
    JUPITER FLA
    Nope just installed them last nite but lite was off today came back on and psi are all at 36
suporter stemss
valve stem hitting caliper
