Single clamp on the rad hose?
Discussion in 'SRT Hellcat General Discussions' started by Nutshell, May 24, 2015.
  1. Nutshell
    Nutshell Senior Hellcat Member
    Mar 18, 2015
    110
    19
    48
    Texas
    My cat has a single clamp on the top end hose and is a pretty recent build (late April) should it have two? I thought there was some sort of recall a while back to add an additional clamp. Just wondering.
  2. cruizinrc
    cruizinrc HCC New Jersey State President Hellcat Car Club HCC Charter Member
    Jan 26, 2015
    877
    403
    Mines the same was told no recalls on my car picked it up Friday
    Ron
  3. Sinurgy
    Sinurgy Silver Member
    Mar 15, 2015
    476
    112
    Same here
  4. Lighty
    Lighty Silver Member
    Dec 20, 2014
    773
    172
    Ontario
    Mine has double on the rad end and single on the water pump.
  5. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,514
    1,428
    818
    Endless Mtns of Pa
    you can check recalls for your VIN at your U Connect online
  6. GreenPirate
    GreenPirate SRT Hellcat Supporter Gold Supporting Member
    Apr 10, 2015
    161
    65
    178
    Eastern North Carolina
    Our Challenger was just delivered and also has two clamps on radiator sine, one on water pump end.
  7. B5 Blue
    1,745
    When was it built?
  8. GreenPirate
    Apr 10, 2015
    161
    65
    178
    Factory release (KZ) 04/16/2015; delivered 05/14/2015
  9. RPM Junkie
    RPM Junkie Silver Member
    Mar 20, 2015
    120
    70
    168
    Hartford, CT
    My HC Charger, Build: May 18, Charger: #484, has the nice new factory installed worm clamp at the low end with the factory clamp. Just factory clamp up top. My parts guy was able to order two of the nice worms (without having to purchase whole hose assembly) and I will install one at the top end this week. Some said avoid this due to unknown pressure levels. Can't speak to that but I think there has been a slight slip in the position of the hose up top since I got her (3,000 miles now). Would rather deal with this known risk then the unknown.
  10. B5 Blue
    1,745
    This was a TSB which in my world isn't a recall so it won't show. Is that correct fnkychkn for Dodge that no TSB shows a recall?
  11. GreenPirate
    Apr 10, 2015
    161
    65
    178
    I've noticed a slight slip too - just a few millimeters - on the water pump end. The flange seems to flare a bit, and this may prevent further slippage. I'll be checking of course.
  12. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,614
    508
    423
    Chattanooga, Tennessee
    The important part is that the single clamp is a worm drive clamp on the upper radiator hose. Initially had a spring clamp and wasn't holding.
  13. Nutshell
    Mar 18, 2015
    110
    19
    48
    Texas
    So if the top end of the hose has one and the bottom end has two we are good, right? I'm seeing two on the lower part but not the top end. Just a single clip style one on top and the same on the lower with another worm style clamp on the lower end of the hose.
  14. Lighty
    Dec 20, 2014
    773
    172
    Ontario
    That is exactly how my charger is.
  15. RPM Junkie
    Mar 20, 2015
    120
    70
    168
    Hartford, CT
    I'm adding one at the top part of the radiator hose beside the factory clip. Both ends of hose will then be identical. Insurance. Another Forum member did it as well (posted a pic) and I think it's a good idea.
