size of injectors
Discussion in 'SRT Hellcat Performance' started by Ray Hunsaker, Jan 9, 2016.
  1. Ray Hunsaker
    Jan 26, 2015
    545
    157
    any one know what fuel injectors are on the stock hellcat?
  2. Senderofan
    Senderofan Track in, Apex, Track out and Repeat! Hellcat Car Club Gold Supporting Member HCC Charter Member
    Aug 21, 2015
    456
    220
    Upper Midwest
    "Feeding the beast
    More fuel was needed to feed the supercharger, so larger fuel injectors rated at 600 cc/min are utilized. SRT also developed a variable fuel pressure system with a pulse-width-modulated in-tank fuel pump."
    The quote was taken from the article: SRT Engineer Explains How Hellcat Hemi Pulls 707 Horsepower - EngineLabs
    The 600cc/min converts to 57.14 lbs/hr.....which you see some injectors rated in lbs/hr. Calculator can be found here: fuel injector flow rates
  3. Senderofan
    Aug 21, 2015
    456
    220
    Upper Midwest
    Are you thinking of upgrading?
  4. Ray Hunsaker
    Jan 26, 2015
    545
    157
    I was debating with my son and I couldn't remember. thanks
  5. Senderofan
    Aug 21, 2015
    456
    220
    Upper Midwest
    OK......Just thought perhaps you were working on performance mods......like to hear what folks are doing.
  6. buddyg
    buddyg Gold Member
    Oct 24, 2014
    1,288
    665
    563
    Michigan (West Coast)
    It's weird because my modded CTS-V with the same horsepower we used ID850's. Seems like the 600's wouldn't be enough?
  7. Ray Hunsaker
    Jan 26, 2015
    545
    157
    Yes that's some of the question how can these work on a hellcat even when they up the boost? and other makes can't ?
  8. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,063
    306
    I'm not sure what fuel pressure the Cadillac uses, but the Hellcat runs 550 kPa (about 80 psi). I bet the injectors are rated at a lower pressure for the 600 cc/min. I also bet most other boosted applications don't run fuel pressure that high.
  9. rednug
    rednug Hellcat Member
    Jan 31, 2015
    39
    32
    18
    Oklahoma City
    I had thought about swapping out injectors, but i'm not sure if it would do any good being stock. What is everyone's thoughts about these? .
    2015-2017 | DeatschWerks
bigger fuel injectors and fuel pump on 2016 392 challenger
challenger hellcat fuel injector brand
hell cat injector size
hellcat fuel injectors
hellcat injector size
hellcat injectors
injector size in a 2016 dodge hellcat
stock helcat fuel injectors
